Pole Barn Loft...framing size questions
   / Pole Barn Loft...framing size questions
I am thinking for the beam to put a 6 x6 post in the center then from the wall posts double 2 x 10s on each side of of all the posts (total 4, 2 x10s). Use Ledgerlok screws at the posts, liquid nail between the 2 x10s, then 3" deck screws in vertical rows on 2' centers on the 2 x 10s. Staggering the joints in the 2 x10s so there will not be any joints inline
   / Pole Barn Loft...framing size questions #12
A few thoughts for what it's worth. There are lots of ways to do these things. I would build a continuous beam for the 30 foot span and I would let it rest on the top of the 6x6 rather that fasten beams into the sides. If you build the beam that is three layers of 2x10's, with two layers of 1/2" plywood laminated it will be the same width as the 6x6. Then you can add some angle braces on the face of the post and beam. This beam will probably end up in the 400 lb range but it will be very substantial.
As far as the loading, the 40 psf live load and 10psf dead load is pretty standard code for occupied spaces. However, if you're building this for your own storage use, you can design it for a lower load. I would guess it's really unlikely you will ever store 10 tons of stuff in this area. So don't get too carried away with meeting code exactly.
Maletti BCV3180 (A53316)
Maletti BCV3180...
LandPride BB3584 (A53314)
LandPride BB3584...
2025 Future 72in Log Grapple Skid Steer Attachment (A55787)
2025 Future 72in...
Takeuchi Skid Steer (A52377)
Takeuchi Skid...
Bush Hog 84" Mower (A53316)
Bush Hog 84" Mower...
Erskine Skidloader Truss Boom (LIKE NEW) (A50775)
Erskine Skidloader...
