Pole barn on plate?
   / Pole barn on plate?
I see so many of those prefab sheds like you are talking about dave1949, and as you say they don't blow away. I guess I am more concerned about the 2X8s rotting and about frost heaving the building so that it is unlevel. It will be a livestock barn, but I would still expect the ground underneath the sills to freeze solid.
   / Pole barn on plate? #12
this is a great alternative to wooden posts in the ground.
https://www.permacolumn.com/
I'm using their sturdi wall brackets....you can see them here (rear 12ft lean to going up):
   / Pole barn on plate? #13
This is my barn in process of building in 1997. It's a kit from shelter-kit in N.H. Design is a modern post & beam using 6x6 pt posts set on a concrete slab. Slab is on prepared base 6" with 1/2 rebar and 2'x2' cubes poured at every post location. I am close to you if you want to see it. (K-055)
   / Pole barn on plate? #14
A pole barn on a plate won't work from a structural standpoint. The point loads of a pole barn need much more than a 2x8 plate to distribute the load.
If you want a pole barn, you need to sink them in the ground below frost or an engineer-approved monolithic slab to take the stresses of the point loads.
If you want to build on-grade you need to go stick framed.
Since you already have the gravel pad, I'd go with a either a monolithic slab or a floating footing with a short (12" - 24") knee wall. Either way, get concrete in contact with the ground/manure.
More importantly, I'd be looking for a different builder/designer. That's WAY too big of a building for what he's suggesting.
Opinion based on being a Licensed Carpenter, 20 yrs experience and Heritage Carpentry Diploma working in the Ottawa Ontario area.
   / Pole barn on plate? #15
The OP stated it is going to be a pole barn. Not a stick built structure. Like comparing apples and oranges.
Actually he said he was working with a builder to design a pole barn, but rather than poles the builder suggested he consider a 2X8 PT plate directly on a gravel base.
I still suggest that should you choose to do that, rather than place your 2X8 PT sill on gravel I would recommend laying block as per my original suggestion if a footing or slab is not in the cards.
   / Pole barn on plate? #16
I just noticed you said two stories. Poles would be probably be better for two stories than stick framing, plus that height will catch a lot more wind. Do you plan on putting hay on the second floor?
For livestock, you don't really want a concrete floor is my understanding. A confinement operation where the floor gets hosed into a manure collection trough is a lot different than animals on bedding.
Old barns and the remains of old barns that I have seen didn't put wood on the ground. They had stacked rock piers to carry sill beams, or a stacked rock continuous foundation wall with sill beams running on top of that. Of course, they didn't have the option of laying down treated sills either. That is where your builder deviates from the old method.
I think you will be happier using more modern methods for a two story building.
   / Pole barn on plate? #17
Welcome to tbn! What is your use for this bldg going to be? Do you ever plan for a slab or heating? I completely agree with another poster(s) that a 2x8 will not be anywhere close to the size timber you'll need to distribute the weight of a pole buildings posts at the typical 8' spacing. I'm thinking more of an 8x8! I have found that if you plan on finishing the interior of a post frame (pole) bldg. it is generally better to just frame conventionaly on some sort of foundation. This is even a bigger factor if you plan on insulating & heating it. I am a big fan of those prema column mentioned previously. I would seriously question your "guy" & what he knows about pole buildings.
   / Pole barn on plate? #19
I understand what you are referring to, but I understood the OP statement as instead of putting the posts in the ground they lay a 2x8 pt board on top of gravel and the posts on the 2x8 plate. This would provide a poor connection between the post and sill plate. All the downforce of the structure would be on the 1.5 inch plate that has no foundation or proper footing underneath it. In your case, because it is stick built, the weight is evenly distributed throughout the block and 6x6 footing. In addition, this is to be a two story structure, not a single story shed.
The method you utilized is much stouter with concrete block and a 6x6 sill plate.
I have been building residential structures for 30 yrs and have more than a few pole barns and stick built structures under my belt. Unless something was missed by the OP in his discussions with the builder, I would find someone else to design and construct the building.
   / Pole barn on plate? #20
The builder I used to haul for built plenty of barns that had the posts on a plate but not on gravel. They would pour a foundation with strategically placed anchor bolts. The posts would be bolted to large galvanized angles bolted to the plate and post.
This company also had a Perma Column franchise/plant. If you take the time to look up Perma Columns, there are steel brackets on two sides of the post that the posts gets bolted to with just a couple of bolts. The steel is welded to rebar that runs through the concrete. This was back around 05' so they may have changed. As I understood it at the time, engineering tests showed these structures to be as strong against wind loads as the standard post in the ground setup.
I have seen precast concrete sections set directly on tamped gravel but these were for foundations. The exterior backfill and interior basement slab stablized the walls. Don't Maine builders also use grade beams on gravel for some applications?
2006 Cadillac STS Sedan (A50324)
2006 Cadillac STS...
2021 Acura RDX SUV (A50324)
2021 Acura RDX SUV...
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
