Pole Barn questions 30' clear span
   / Pole Barn questions 30' clear span #21
OK lots of info...
I use regular galvanized for almost everything in an outdoor structure. They are only a few dollars more per 2500 box. If you ever hose off the inside of the barn you won't have rust streaks. If they are OK for the new PTL lumber they will say so....usually "hot dipped" or "double galvanized" etc. I prefer stainless though. They cost about 2-3x the others but will last. I only use them were they are needed...not everywhere.
Most recommend you do NOT screw or nail metal siding/roofing to any of the new PTL. The electric continuity will preferentially rot your expensive metal. It becomes the sacrificial anode in the mix--the outside is galvanized to protect but the nail/screw will pierce this thin coating and make electrical contact with the old fashioned ferrous metal. You can put a non-PTL board just above your base skirt board and attach the siding to that...just let the siding "hang" the last few inches over the PTL skirt board. I would even separate that overlap with somthing like roof felt or even adhesive roof felt/flashing cut into the right width for your overlap.
You may be able to get the older style PTL also. I still get it locally (a load less than one week ago to be honest!) from Holmes lumber (they are actually now owned by Carter so you may get it there also). I have only gotten the posts (6x6") so I am not sure if they have regular 2x material also or even the T&G skirt boards. The posts actually cost LESS than the new PTL! My understanding is that you can use it for AG use since the new stuff may be toxic to some goats.
Notching the top of the post is common in most areas. Notch the post I believe is OK. Notching a 2x material is not (it significantly reduces it's load bearing ability.
Now for the auger. It may be worth renting a skidsteer with auger for a few hours. You can then drill a 24" hole and get a really solid pad below your poles. I have also used my small backhoe to dig a relatively straight hole if I only do a few posts. If you don't want to do this you can drill with a 9" auger...just be accurate! The problem is not just the angle of the hole with the smaller auger(you can clean that with a manual post hole digger). The bigger problem is the inability to "slide" your poles in the two dimensions required to get the poles to line up perfectly for a straight wall and the post exactly the 8' or 10' apart that you design your building for. Keep in mind you can vary the distance a small amount. Often people will shorten the space between the end poles to allow the wood or metal panel to overlap the corner. It is easier to cut the panel than to add a 2" piece! All that means is know your panel dimensions well and build to minimize(aka never need) any cutting. You may even need to lengthen the space at the last poles an inch to give room for the panel and the corner trim...it all depends on your panels.
Hopefully I have helped and not ruined your day!
Peter
   / Pole Barn questions 30' clear span #22
I'm looking into every suggestion. It's funny, I built this house almost 20 years ago with a gambrel roof. I built the small shed with a gambrel roof. Both were either for an upstairs or storage. Since this is neither, I did not consider the idea.. Of course, I built both of those by stick though...
I did call the truss guys today, and a sissor only gets a 2/12 pitch inside, which did not get me high enough. I will call again tomarrow and ask about a gambrel. Hopefully the cost won't be prohibitive. Otherwise, I'm going 10' walls with standard truss's.
I got a quote for gambrel trusses 28' foot wide a few weeks ago. They were about $120ish. To be able to transport them down the road they came up with a 17.45:12 and 4:12 pitch on the outside and I think a 9:12 pitch on the inside (I have the design around here somewhere). The center cord was about 12' wide. The center cord was about 6' above where it sat on top of the walls. But they were designed for a 60psf snow load and to sit on top of a 2' knee wall.
I had a hard time getting the designers to understand I didn't want any eaves. They wanted to add them for insulation purposes. Instead I'm going to add a flare to the truss (or maybe price having them add it). The design they came up with is much more complex than it needs to be due to the eaves. I haven't gotten a new quote yet but don't think the price will change much.
OK lots of info...
Peter
You have certainly NOT ruined my day! :) I appreciate the input.
Also, I will likely dig my holes now with my backhoe!
2021 Ram ProMaster City Van, VIN # ZFBHRFAB6M6T98722 (A53422)
2021 Ram ProMaster...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
Flatbed Trailer (A51694)
Flatbed Trailer...
UNUSED Black Outdoor Patio Fabric Screen (A53117)
UNUSED Black...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
