HCJtractor
Veteran Member
- Joined
- Jan 28, 2009
- Messages
- 1,519
- Location
- upstate South Carolina, Greenville
- Tractor
- Kubota M6800, Massey Ferguson 240
Great input on the trail work...right on target with my trails...I am cursed with balsam trees...they grow like weeds here. I agree that I need to cut them at the base and just get rid of them. My trails also need to be widened a bit....larger than a Polaris Ranger and close to car size.
I do need a longer saw but not nearly as often. I have sugar maple on my home property that I need to trim up pretty high to get a bit of sunlight in. Also, some pine at our cabin that I want to limb as they grow...lower branches die out and would like to clean up the trees and let in light...really looks nice. Norway/Red pines are my hobby.
I think the problem with my manual pole saw is that it is both cheap AND dull. I think I will take a look at an upgrade of that and see how long I can get...they are exhausting working overhead...but not that many branches to trim...nothing like the work that needs to be done on the trails.
Thank You...you have been very helpful...Tom R in Two Harbors, MN
A great source for pole saws (manual) ia Sherrill Tree (SherrillTree Professional Tree Climbing Gear), a professional arborist supply, that carries everything tree related. Their catalog is very informative, if you like trees. They have many different kinds. They sell an ARS 20' (item 28755) for $262 which is the same saw Sthil sells with a different label and color. They also sell the repalcement blades. The "Hayauchi" also looks nice, but I have never used one. It is cheaper ($195). I have owned three of the ARS and they are great. But be carefull with it. It can be bent if a heavy limb strikes it (or if you step on it like I did) and it may ruin the telescoping feature. I also use the pruner head (loppers) sometimes, but that is usually for trimming ornamentals or landscaping trees around the house. They will cut limbs up to 1.5" But any manual saw is tough work! For the occasional cutting high limbs around the house, they are great. But for extensive road word, you have to have power saws.
One last thing. When you cut trees down alongside the road, cut them short near the ground (but don't touch the chain to the soil!) If you leave them high, they will be like punji stakes if you ever get a tractor and will flatten your tires if you decide to bush hog wide. Found this out the hard way.
Oh, you definitely need a tractor!!! Its way more fun than chainsaw work.
