Pole Saw...Comercial Grade Gasoline
   / Pole Saw...Comercial Grade Gasoline #21
I have a Stihl KM 110 Kombi-motor with the little 12" chain saw on a 4ft shaft attachment. I like it for cutting off limbs close to the ground.
We limbed up 20 acres of pine and spruce for a fuel-break project at work. The guys really preferred the lightweigt aluminum Stihl pole saws with the curved saw blade instead of the powered blades for working up high. Keep WD-40 on the blade, have an extra sharp saw blade and find a good saw shop that can sharpen and set hand saws.
For stuff that resprouts at the ground, use a cut-stump herbicide treatment with concentrated Roundup or Garlon 4 and diesel fuel to the stump.
SC
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A55314)
2023 Kubota L3560...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55314)
Koyker Loader...
2011 Ford Crown Victoria Sedan (A55853)
2011 Ford Crown...
2008 JLG 800AJ MANLIFT (A52707)
2008 JLG 800AJ...
