Pole shed?
/ Pole shed? #1
newtattoobob
Northeast Ohio
Kubota B2650, Kubota BX1850, RTV900XT Worksite, Kubota U17,1942 Farmall H, 1950 Ford 8N
In the near future I am going to be building a 30x40 pole building. The spot where I am going to be putting it is wooded now I am in the process of clearing it out. I plan on putting a gravel floor in, my question is how deep do I need to dig before I put the base down? Also how deep should the footer be, and how far in the ground do the poles need to be? Any input would be appreciated! Thanks Bob
/ Pole shed? #2
Depth of footings are a function of location and soil.
Fill out your bio and that should help with answers from forum members.
welcome
/forums/images/graemlins/grin.gif
/ Pole shed? #3
</font><font color="blue" class="small">( my question is how deep do I need to dig before I put the base down? Also how deep should the footer be, and how far in the ground do the poles need to be? )</font>
For a pole barn that isn't going to have a concrete pad, but just gravel, the depth of material isn't very important. The reason you remove the topsoil is it will compact and move. If you pour concrete on topsoil, it will crack and settle. If you put gravel on it, not much will happen.
Pole depth depends on where you are, your frost line and how deep can you dig. Here, four feet is best, but most people just go three feet since that's what our post hole diggers will do. We don't freeze here and the clay will hold onto a post three feet deep with no problems.
Why 30 by 40?
Most demensions are based on four foot increments for siding and three foot widths for metal roofing. The four foot rule applies for 8 and 12 foot spacings also. I just like four foot to keep it simple.
/ Pole shed?
I am really not set on 30x40 but I was thinking atleast this big to fit my equipment in. If I was using the four foot rule what kind of dimension could I have that would be close to 30x40? Thanks Bob
/ Pole shed? #5
28x36 or32x40 might be a good dimension ,depending on your needs for space. Also how much Heigth do you want ? John
/ Pole shed? #6
I've always thought it peculiar that Carter Lumber advertises their pole barn packages in 24, 30, and 40 foot widths.
Why does a large company use 30 feet? It isn't divisible by four or eight. /forums/images/graemlins/confused.gif
/ Pole shed? #7
I know this guy who's always doing things that make me scratch my head and wonder what he's thinking.
He has a couple acres and decided to build a shed. He wanted a barn style gambrel roof.
When I went by to look at what he had done, which he was extremely proud of, I couldn't help but notice all the scrap material he had lying around. Then I looked closer and realized he had all sorts of little pieces of plywood on the corners.
He said his measurements were a little over 9 feet by 13 feet. The sections of the gambrel roof were also odd and had to be custom cut with a load of scrap.
You can make any dimensions you want, but proper planning wil save you money on material and time fitting those odd sizes.
A good lenghth is 48 feet. You can use 4 foot sheets of siding, your post spacing can be 12 feet OC or 8 feet. It's plenty long for just about anything, but a good size to build yourself.
Width isn't affected by the 3 foot widths of metal roofing, so anything in a multple of 4 works. I'd say 24 feet would be a good start. Depending on how your going to span the roof will dictate your width. If you're going to buy pre made engineered trusses, the length of the span will dictate you price.
If you are making your own truss's, then price isn't so bad, but you need to know what your doing. Especially if you go past 30 feet.
Of course this is all related to wood construction. If you're going the metal route, then buy the kit and it's all cut to size and ready to put together. No waste or concerns about saving on material by avoiding waste.
Eddie
/ Pole shed?
I was thinking of probably ten foot height so I will not have to duck when I pull my tractors in and out. I am planning on using wood for the frame and covering the sides and roof with metal and maybe leaving one side open or maybe a sliding door on one end. As for the roof I am not sure if I should go with a peaked roof or a roof just slanted to one side. Basically I am just looking for something to keep the rain and snow off of my equipment.
/ Pole shed? #9
Do a search on google under Loafing Sheds. They are three sided ones for animals mostly, but just might be what your looking for.
If you do build four walls, you might want to reconsider the slider door. Do a search on this site about them. Lots of folks have em, not many like em.
/ Pole shed? #10
<font color="blue"> Depth of footings are a function of location and soil. </font>
True, and my 28'x40' Pole Barn poles are 8' deep.
/ Pole shed? #11
</font><font color="blue" class="small">( I am really not set on 30x40 but I was thinking atleast this big to fit my equipment in. If I was using the four foot rule what kind of dimension could I have that would be close to 30x40? Thanks Bob )</font>
Go with at least a 32'x40'. I'm looking at adding 14' or 16' x 40' to mine.
/ Pole shed? #12
</font><font color="blue" class="small">( I've always thought it peculiar that Carter Lumber advertises their pole barn packages in 24, 30, and 40 foot widths.
Why does a large company use 30 feet? It isn't divisible by four or eight. /forums/images/graemlins/confused.gif )</font>
Because it doesn't matter how much they overlap.
/ Pole shed? #13
</font><font color="blue" class="small">( You can make any dimensions you want, but proper planning wil save you money on material and time fitting those odd sizes. )</font>
I remember when the professionals showed up to do our barn.
I actually ask them when the materials came if they where expecting another delivery.
They looked surprised at my question.
I could not find a scrap bigger than a 6 inch 1X4 when they were done.
Leave it to the experts to teach you proper technique.
-Mike Z. /forums/images/graemlins/grin.gif
/ Pole shed? #19
Yes. But not wasting server space!
/ Pole shed? #20
I am in the process of building a small (24x27) pole barn. I was going to use sliding doors. What are the problems? Should I reconsider?
2014 John Deere 350G Excavator (A60352)
2014 John Deere...
2020 Chevrolet Tahoe SUV (A61569)
2020 Chevrolet...
Tank Only (A59076)
Tank Only (A59076)
2016 TAKEUCHI TB216 EXCAVATOR (A62129)
2016 TAKEUCHI...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
Kubota L2501 (A62177)
