Possible to stack 2 blades on a mower deck spindle?
   / Possible to stack 2 blades on a mower deck spindle? #21
   / Possible to stack 2 blades on a mower deck spindle? #22
I have installed these 4-bladed discs by Meg-Mo Meg-Mo Systems - Lawn Mower Blades, Replacement Mower Blades, Sharpen Lawn Mower Blades, Mulch Grass on my Kubota G1800 mower which give me 12 cutting tips rather than 6. The high-lift tips give more suction and chop the leaves better. I use this combination to chop leaves for mulch. Takes about half the passes of the regular blades. Tips are replaceable too. Something to consider, maybe.
HTH
Arkaybee
Those blades are way cool!:thumbsup: That should put my G1800 on steroids. I'll have to see about getting some. Thanks!:)
   / Possible to stack 2 blades on a mower deck spindle? #23
I have been running doubles on one of my mowers for about 10 years. The best combo I like is high lift on top, reg. lift on bottom.
I would not weld them or bracket them. Want some give to them should you hit something.
   / Possible to stack 2 blades on a mower deck spindle? #24
I had a 1950 Gravely L series brush Hog that used a two blade system. It was a very heavy duty machine, and it would cut down a field of ax handles if it had to. The two bladed system worked well.
   / Possible to stack 2 blades on a mower deck spindle? #25
Old, thread but I'm looking to try doubles as well. I'd like to hear more about peoples combos. I've heard that some use the G6 and a "wavy" blade which I can't seem to find. I currently have a gator style blade, but I'm not sure if its a G3 or a G6. Oregon doesn't list a 25" G3 for my deck so it might be the G6.
Yes, I remember the old Gravelys had a double 30" blade. There was a cross plate the kept the blades from stacking. I remember hitting something once and turned the blade forcing the cross plate to flatten out. Ended up having to cut the spindle bolt off so we could remove the blades.
2015 Komatsu PC138 (A47477)
2015 Komatsu PC138...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A55218)
2022 JCB 3TS-8T...
2011 Kia Forte Sedan (A55853)
2011 Kia Forte...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
UNUSED FUTURE RT57 57" HYD ROTARY TILLER (A57193)
UNUSED FUTURE RT57...
