Possible to use a slip clutch on the tractor side of a PTO shaft?
   / Possible to use a slip clutch on the tractor side of a PTO shaft?
Congratulations Bill the most important part is in the end you overcame the problem, and won the battle saving an otherwise good piece of equipment from the scrap yard. For some strange reason when I run into a problem like yours I can't stop working on it untill I have either solved the problem or ruined it beyond all chance of repair. But since it is already ruined the only chance you have is to make it better:D
Sometimes the simplest solutions are the ones that we don't even think about especially when we already have the "proper tools for the job", I.E. gearpuller, such as using a sawsall or side grinder with a cut off wheel or even a circular saw with a metal cutting abrasive wheel to cut a slot completely through the coupler parallel to the shaft. Once you get the slot cut you can drive in a cold chisel as a wedge to spread the diameter of the coupling alowing the penetrating oil to reach the rust. It is time consuming but isn't hard work. This only works of course if you don't mind destroying the origional part. I have used this method several times, it always works.
I once used a circular saw to cut lengths of 6 x 6 x 1/2 angle iron to build a hitch for my motor home. My torch was out of gas, my grinder was burned up I didn't own a chop saw and I wanted to get it done without making a trip into town. Wow that was a noisy process:eek:
The maintenance pipe fitters at Dow chemical recomend something called PB-Blaster for rusted parts. It seems to actually disolve rust if you can get it to it.
Of course there is great satisfaction to be had by just beating it into submission like you did, once again congratulations.:D you won!!!!
Cutting a slot is a great idea, I hadn't thought of that. Very creative, thanks.
As for saving something from the landfill, my wife tells me I do too much of this. Although if something has to be recycled, a rotary mower is probably a good candidate, it seems to be 95% steel.
I am glad I got it working though. I cut the pasture yesterday and it seemed to work fine, although I must admit I STILL (even with lots of advice herein) don't know how to adjust the new slip clutch just right.
I think I'm going to take the slip clutch off over the winter and cover the mower spindle, might cut down on the rust.
BTW, I did use PB Blaster!
   / Possible to use a slip clutch on the tractor side of a PTO shaft? #22
why aren't sizes stamped on PTO shaft yokes?
They are on mine. The "4" on a Eurocardan means it's a model 4. This is a bit oversimplified, but everything with a "4" on it is generally compatible within the Eurocardan line. Get two yokes and a cross that are stamped "4", and they'll mate with a "4" shaft and a "4" tube and ends. I believe they have at least model lines 1 through 6, maybe more. Can't speak for other manufacturers though.
If yours is a Eurocardan, you should have gotten instructions with it about how to tighten the springs to match your PTO horsepower. If yours is a Eurocardan "4" but you didn't get the instructions, I can give you those numbers.
//greg//
I'm guessing I was wrong assuming I was protected, because I didn't adjust my slip clutch at all after putting it on, so I bet the springs are too 'tight".
My slip clutch is a Weasler. It didn't come with any instructions at all. Here's a pic from tractor supply:
PTO Slip Clutch, 1-3/8 in. 6 in. Spline Shaft - 0271211 | Tractor Supply Company
if that link doesn't work at Tractor Supply Company - Home it can be found by searching on 'weasler slip clutch'.
I checked the weasler website and there is no tech info. anyone know how to adjust one of these slip clutches via the 'measuring spring length?'
It looks very much like the pics of the eurocardan. Maybe I could start with those settings and then test to see where it slips.
   / Possible to use a slip clutch on the tractor side of a PTO shaft? #24
Bill here is an adjustment procedure for that type of slip clutch.
  • PTO CLUTCH ADJUSTMENT.pdf
Randall,
Thanks very much for this -- since it looks like the starting point here is 1/2 turn instead of 1 1/2 turns, this will save me a lot of time. Appreciate it!
   / Possible to use a slip clutch on the tractor side of a PTO shaft? #26
Your welcome. I think the idea on the slip clutches is to adjust it a little more than it needs to run the implement(mower) without slipping. Most people put the mower into high grass for a test adjust-slip-test, adjust-slip-test, adjust-slip-test, adjust-noslip, adjust a little more and your good to go. Thats a safe way to protect your gear box, test it on the heaviest stuff you will be cutting starting from a slipping condition adjusting to a no-slip condition.
2018 Kia Optima Sedan (A55973)
2018 Kia Optima...
2006 FORD F-350 (A53422)
2006 FORD F-350...
2011 Ford Econoline Cargo Van (A54814)
2011 Ford...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
CONTACT INFO (A53084)
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
