Post Driver with Top & Tilt
/ Post Driver with Top & Tilt #1
hcf
Styx, MO
BCS
Hi All,
Will be getting a Shaver HD-8 post driver and am wondering if I could use Fit Rite Hydraulics Top & Tilt system (or equivalent) to level the post driver. Have seen rave reviews about using the Top & Tilt for moving/shaping dirt, but haven't found any mention of using it with a post driver. Is there anything about the post driver operation that would shorten the life of the Top & Tilt?
The Top & Tilt looks to be cheaper than the Shaver hydraulic leveling option, and a lot more versatile.
Thank you for your time
/ Post Driver with Top & Tilt #2
I wouldn't think that there would be a problem. What tractor are you going to use this on?
Hi Brian, - Was hoping you'd chime in.
The post driver will come with a LS5030C tractor attached for a small extra charge.
Because of the height of the driver it may be possible smack the top of the cab with the driver. If so, I'll have to approach posts from the downhill side so the driver will be angled away from the cab.
While the T&T has many happy users that apply mostly horizontal force with earth shaping tools, I'm concerned that the mostly vertical jarring from the post driver might be a different situation. Am hoping that someone has already done this will chime in also.
As the hydraulic tilt option for the Shaver is about $1000 and is dedicated to that one attachment, the T&T could prove to be popular with post driver owners.
/ Post Driver with Top & Tilt #4
Based on looking at the hydraulics in the operator's manual on page 42, I see no reason why Top & Tilt cylinders would not work. Doesn't look like they use anything special to me. We could use 3" cylinders instead of 2 1/2" if you feel that would be any better. Keep in mind that my units come with a limited lifetime warranty. ;)
Thanks for the prompt replies. Will call next week as I have a long list of questions regarding the best way to provide a 3rd remote to power the post driver.
/ Post Driver with Top & Tilt #6
Get the OEM 3rd rear remote with the tractor.
When I talked to the regional rep from LS I got the impression I couldn't order the tractor with a 3rd remote. Will check into getting a kit from LS.
/ Post Driver with Top & Tilt #8
I suppose that might be so, I know that on the 41s & 47s that they have 2 std and a 3rd is available. Other wise just go with a diverter valve and use that with the "TnT" set.
2021 Vermeer STR48 Hydraulic Trencher Attachment (A64912)
2021 Vermeer STR48...
2016 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2016 Chevrolet...
2018 JOHN DEERE 350G LC EXCAVATOR (A65056)
2018 JOHN DEERE...
PALLET OF FUEL TANK AND TOOLBOXES (A68842)
PALLET OF FUEL...
2011 CARGO CRAFT ENCLOSED GOOSENECK (A67714)
2011 CARGO CRAFT...
2020 AUTOCAR XSPOTTER TRUCK (A65057)
2020 AUTOCAR...
