Barryh
Veteran Member
- Joined
- Jul 5, 2005
- Messages
- 1,588
- Tractor
- Former owner of a P T -180 / Kubota BX-1500 .. A Craftsman Yard Tractor / John Deere 140 H-1 / Cub Cadet 108. And now ( Little Red ) a Power Trac 1425
Keith,KeithInSpace said:Actually, I'm the person that Mr. AceDeuce sold his PHD to. I haven't had occasion to use it. I'm going to be digging holes for my Dad's privacy fence in the spring.
When I mounted it on my 2230 immediately after purchasing, I could lift the tip a solid 6 or 8 inches off the deck. I could definitely see dragging the tip if you transport the unit with the auger attached...unless your project is at the end of your driveway, I'd say it is far more likely that you would drive to the project site WITHOUT the auger attached, then slap it on once you get to where you don't care if the tip drags/digs in the ground.
I think the only difference between the BX1500 and my unit is the high of the tires.
my projects this summer are very similar to yours, I want to slowly put up a rustic wood fence around my 1-plus acre most of it would require dragging the post hole digger, through the wooded areas up and over some small ravines and such. Never using or having a post hole digger before this discussion is very helpful, now I know what to expect.
I like Jim Browns idea, sounds like the way to go. Put a strap on the auger and pull it up into the unit. If not, like you mentioned transporting the auger to the area, attaching it on the spot is not a problem. I'm also wondering if transporting water to the area to do a little pre-soak might help make the job of drilling easier. Thanks for all the feed back guys.
