POST HOLE DIGGER
   / POST HOLE DIGGER #1
CHRYSLER
Hiram,Ohio
2003 JD 4310, FEL, JD brushog ,JD 855 FEL,backhoe, tiller,post hole digger,box blade, 1997Cub 2197 , 1953 Cub , 2004 cub cadet 54" zero turn
I have a 3 point post hole digger that I just tried using today and the auger will not turn, the drive shaft going to the box is turning but the slightest pressure on the auger will stop it although the drive shaft continues to run, worked last year just fine, do not know the name of the unit, most likely the gearbox, what goes wrong with them?
   / POST HOLE DIGGER #2
If you checked for a sheared bolt, then it could be a gearbox issue. Perhaps there's a drive pin fastening one of the bevel gears that has come loose- the friction of the shaft/gear fit is enough to engage the auger, but when there's a bit of pressure on the auger, the shaft slips? Good luck.
   / POST HOLE DIGGER #3
Is the unit shear bolt or slip clutch style?
Sent from my Milestone X2 using TractorByNet
   / POST HOLE DIGGER
from what i know about it its a shear bolt style
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
Volvo A40D Off Road Dump Truck (A56438)
Volvo A40D Off...
2001 Workhorse Custom Chassis P42 Delivery Truck (A59230)
2001 Workhorse...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
