Poured retaining wall - Sloped vs Stagged top
   / Poured retaining wall - Sloped vs Stagged top #11
When I built my shed with 8 foot walls, half in the ground, my building inspector was absolutely **** about the reinforcing particulars as it was set into a hillside. A bigger issue before the interior floor was poured midway up to support the wall.
For smaller castings, I often put a carriage bolt in a hammer drill and run it around the form. It works amazingly well. Bummer when you make some nice form details and the concrete isn't in good contact.
Someone should be able to tell you what slump to order.
I think this was a bit steeper
Thanks for the picture. I may have used poor wording. The wall itself is vertical, only the top of the wall is sloped/tapered down to a reduced height.
   / Poured retaining wall - Sloped vs Stagged top #13
Most locations require any wall over 4 feet to be designed. Drainage behind wall is very important
I've done a fair amount of concrete work, but I'm not an expert or even close. Retaining walls fail on a regular bases because of the amount of pressure put on them by the soil when it gets saturated with water and even more so when the soil freezes.
An 8 foot wall is way above where I'm comfortable designing or engineering. How deep will your footings be? Will you have posts along the wall? What size rebar will you be using and at what spacing? Will you incorporate a deadman? What thickness will your wall be? How will you brace your forms to deal with blowout?
Instead of pouring a concrete retaining wall that tall, I would go with retaining wall blocks engineered for an 8 foot wall and allow for drainage behind the wall. Then I would cap it with concrete to give it that smooth finish on the top that you are wanting. This is very common.
I am certain you have done more concrete work than I Eddy and am glad you chimed in.
Couple things to note about the wall and to answer your questions.
Footings are already poured. 27" wide - 18" deep in undisturbed heavy clay soil.
The top of the retaining wall footing is a few inches below the footing on the house.
1/2" rebar every 2ft horizontal and vertical.
The soil on the back side of retaining wall actually will slope away from the wall which will chase runoff down the hill and away from the wall.
Will not have posts along the wall.
Deadman are likely not going to be used but I could certainly do so.
Wall is going to be 10" thick.
The steel-ply forms come with adjustable turnbuckle braces and of course the form ties really are what hold the forms together.
Now as far as drainage behind the wall, I plan to fill rock/gravel about 3' back and up about 4-5' as well as run corrugated tube in at least 2 spots to chase water. I have not planned for any spillways or seepage through the wall. I will also be using geotextile fabric to keep the rock from being filled with dirt/mud.
One of the main reasons I want to do a poured wall is time. I am running out of time this year to get my outside projects done due to abnormal rainfall. I still have 100yds of flatwork to do and this retaining wall needs done before some of that can be done.
Let me know your thoughts. I have some time to change my mind on certain things.
Understood and agree with you.
   / Poured retaining wall - Sloped vs Stagged top #16
No, I understood. Just thought this might show that your slope shouldn’t be a problem with proper slump especially with a form.
Excellent. Thanks for your reply and thoughts.
Your signature link is quite timely, will be heading your way in March for the 1st time... Really looking forward to it!
   / Poured retaining wall - Sloped vs Stagged top #18
Myyaz
Will this wall be supporting your foundation. If yes someone should actually design wall
Vertical rebar should be closer to 6" on center. Horizontal rebar 12" oc
Footing appears to be narrow for the height
Myyaz
The wall will not be supporting the foundation. Horizontal rebar could be adjusted to 12" and I can drill to add more verticals. Not sure if scabbing on to the existing footing is a wise idea or not. I could do it at the time of pour pretty easy if I just take the backhoe along side the existing. Thanks for the input.
   / Poured retaining wall - Sloped vs Stagged top #20
If coming to Big Island, let me know. Pretty much open invitation to TBN visit when in area.
30in Forks and Frame Mini Skid Steer Attachment (A55851)
30in Forks and...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
22 TON PNEUMATIC JACK (A55745)
22 TON PNEUMATIC...
2020 VOLVO VN SERIES SLEEPER (A55745)
2020 VOLVO VN...
Heavy Duty Aluminum Service Truck Bed Rack (A55787)
Heavy Duty...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
