Boondox
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 3,871
- Location
- Craftsbury Common, Vermont
- Tractor
- Deere 4044R cab, Kubota KX-121-3S
Wow, I just did exactly that with my L3010! It went okay, but not as fast as I had expected. My slab was tiny -- just 9x16 -- and it took a lot more trips than anticipated. Still, it was much easier than using wheelbarrows! Some observations:
First, concrete is heavy! The front end really took a dip every time I got a load, and that was with the backhoe on for ballast. Hope you have some decent tires! Secondly, concrete is messy. Don't expect to be able to take full bucket loads. My bucket holds 1/2 yard, but I had to take much less to avoid leaving big splats all over the place. In the end each load was about 1/4 of a yard, maybe a little less until I figured out that raising the bucket to hood level let me carry more. But carrying it that high made me nervous! Thirdly, expect ruts unless you have enough room to make each trip on a slightly different route. One or two trips wasn't bad, but by the third trip I got some serious turf damage. I should have had some sort of lumber on hand to save the soft spots. Fourth: have someone guide you into position. I had to keep the bucket raised fairly high to avoid sloppage, and that cut my forward visibility into the drop zone to zero. Fifth: order a little more than you think you'll need, then add 10 percent to that. Better too much than too little. And have another small project that needs that extra concrete so you don't have to do the last minute "How do I use up that yard?" decision. Sixth: offer the delivery driver a hot cup of coffee or cocoa right up front. It's a PITA for him to dispense bucket loads at a time, so make him your friend and ensure his cooperation.
