Pouring That Diesel
   / Pouring That Diesel #11
I'm really glad you finally got your tractor and are out doing things with it. You're providing a lot of ideas and inspiration for a lot of us that simply accept some things as part of life. After seeing your fuel can rig, I've already though about how to rig a pulley system to do the fuel can lifting for me with just a simple pull on one rope. Thanks!!!!!
Bob Pence
Bob -
I think we're headed in the same direction with the pulleys.
Keep us all posted and we'll compare notes later on. /w3tcompact/icons/smile.gif
   / Pouring That Diesel #13
Harv,
For five years with my Massey Ferguson, I climbed up on the loader, leaned over the hood and filled the tank from the 5 gallon cans.
The Yellow cans I have now are Junk and leak when pouring. They have the center pull out extensions and these do not work nearly as well as the fixed pouring extensions that the Red Cans have.
My Kubota fills in the REAR now. It is not hard to fill from 5 gallon cans, but looking for a bigger container and a hand pump before next spring. The Massey (40HP) and the Kubota (68HP) both get almost identical 1 gallon per hour for heavy duty operation at PTO speed, so they use very little fuel in a day.
It sure is nice to have a tractor that the gas gauge works on. I used a stick for years to check the gas level.
Glad you are enjoying your new tractor!
Diesel comes out of jeans with normal washing. /w3tcompact/icons/smile.gif
   / Pouring That Diesel #14
Harv,
Don't put every ounce you can into the can when you fill them up. Carry a extra can if you need to. When they are full, you barely tip them and they are spilling. They're also heavy.
The other thing is to find a old style filler neck. Most cans have filler necks for unleaded; it's WAY to small and takes to long to pour.
Oh, and get at least a little dirty for the pictures/w3tcompact/icons/laugh.gif I don't know anyone who can stay that clean around equipment /w3tcompact/icons/wink.gif
RobertN in Shingle Springs Calif
RobertN -
<font color=blue>Don't put every ounce you can into the can when you fill them up</font color=blue>
I put about 5.1 gallons in each one. Yeah, they're kinda heavy, but with the caps screwed on tight I haven't had any spilling problems (so far).
<font color=blue>Most cans have filler necks for unleaded; it's WAY to small and takes to long to pour</font color=blue>
The diameter does seem kind of small, but like I said, once hoisted, they drain themselves in less than a minute. I can live with that. /w3tcompact/icons/crazy.gif
<font color=blue>Oh, and get at least a little dirty for the pictures.</font color=blue>
Actually, the inadvertant trick I pulled in that photo was to slip my long-sleeve shirt back on 'cuz it was starting to get cold. Underneath is a plenty dirty T-shirt, and the tractor is hiding the matching blue jeans. /w3tcompact/icons/wink.gif
Wen -
You're a tougher man than I am to manually pour from 5-gallon cans for 5 years. /w3tcompact/icons/tongue.gif It kinda makes me wonder what the tractor manufacturer had in mind by placing the fill spout on top like that. I guess they were assuming all these tractors would be used on commercial farms with actual fuel-pumping facilities?
<font color=blue>Diesel comes out of jeans with normal washing.</font color=blue>
Should I show this comment to my wife? I've been arguing that her detergents are sub-normal in cleaning strength for years. /w3tcompact/icons/smile.gif
In fact, hold on a sec -- I just checked and Simple Green did a magnificent job on removing the diesel stain andsmell, as well as removing some other stains that have been there for ages. Great stuff!
   / Pouring That Diesel #17
Tougher - no, more persistant - maybe.
Almost all things on tractors were done for very good reasons. A fuel tank ABOVE the injector pump (or carb on a gasoline engine tractor)does not require a fuel pump. It is strictly gravity feed. Cheap and reliable. The old Farmall used a crank. No battery, generator, starter or electrical system. If you look at each and every part of an older tractor, there is probably a good engineering (and cost) reason for it being the way it is.
Modern tractors seem to be designed more by feature people (marketing types)and sometimes the features don't make a lot of sense, are more complex than they need to be to get work done, or just simply drive up the price. The Farmall was bought for $500, the Massey (2WD) for $12,000 and the Kubota (M6800 with 4WD) and Loader for $27,000. See what I mean.
The Kubota really does have excellent engineering throughout. No other tractor will hold a candle to Kubota when it comes to the engine or drive train reliability and value. Everything works exactly as it should and no matter how hard you try, you can't come up with a better way to do it. My diesel tank(s) are under the tractor, but about 15 inches off the ground and well protected which allows the fuel to be filled from the rear. After all those years climbing up on the hood, this is really nice. The adjustable links on the 3 point are also really nice features. Hard to find something that doesn't work well. You will love your Kubota for many years to come.
   / Pouring That Diesel #18
Wen -- Kubota / JD
Hi Wen,
Re. Kubota, you say:
[["Everything works exactly as it should and no matter how hard you try, you can't come up with a better way to do it."]]
Maybe you're the guy to help me understand the reasoning for the "turning-brake" pedal(s) being on the same side of the deck as the hydrostatic-control. The local Kubota salesman gave me a "lame" explanation..." As tight as these things turn, you wouldn't want to use brake-turns anyway".
That may or may-not be true, but it doesn't turn a bad control-layout into a good one.
In my admittedly relatively-ignorant state, JD seems to get the edge on this point... but I'm willing to be convinced.
Talk to me, somebody!
Larry ( teetering on the brink of a JD 4700 )
   / Pouring That Diesel #19
Re: Wen -- Kubota / JD
Larry, Wen has a geared tractor, so that's not a concern for him. So, for your question, yes, the John Deere has the advantage in that regard if you want to use the brakes for steering. I don't need that feature, although I do on rare occasions use it with the cruise set. And of course the new B2910 has a hand operated lever you can use instead of the foot pedal so you can brake steer.
Along the same lines, the cruise releases if you step on the hydro pedal or both brakes, but does not release if you step on the clutch or one brake. Has anyone tried setting the cruise, then use the clutch and one brake for steering in basically the same manner as you would on a geared tractor? I haven't tried it, but see no reason for it not to work just fine.
Bird
   / Pouring That Diesel #20
Fellow fuelers...
Went to store, bought siphon typically used for kerosene heaters, pump and fill away. Isn't necessarily the fastest, but I'm not in any race. You could always add either a second siphon or suck from two cans simultaneously if your REALLY in a hurry, though I doubt anyone would suggest that. I find it's easy to fill, easy to watch, easy to KILL when time is to terminate.
I have to point out though, that on the machinery we have, setting cans on top of hood isn't a big issue.
Poor Uncle in law (80 years young)... up until I came along, always muscled 5 gallon cans, had spout flipping around, always trying to clean dirt accumulations out of the spout prior to filling...
Now the only hard part is hoisting full can to top of machine.
Hose Reel (A55758)
Hose Reel (A55758)
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
