Power beyond kit for 2305?
   / Power beyond kit for 2305? #1
orlo
Platinum Member
Guildhall, VT
JD 2305/JD 4720 cab
Hi: Does anybody know any aftermarket kits offered to route 'power beyond' hydraulic couplers to the rear of a 2305 (or a 2210 kit would probably work too).
I'm thinking (not sure yet) about a back hoe and maybe a 3pt log splitter and figure it would be silly for me to get both with a PTO pump. It would be easier to just have the couplers at the rear also.
Thanks,
   / Power beyond kit for 2305? #2
It would be pretty easy to make if you are mechanicaly inclined.
Just install a Tee at the pump on the lines that go to the diverter valve(s) and run 2 hard lines or hoses back to couplers mounted on the rear.
Just make sure you use the correct pressure rated hoses, fittings and tubing, protect them from rubbing on stuff and DO NOT use teflon tape on hydraulics. If you need to use a sealant use liquid teflon.
   / Power beyond kit for 2305? #3
You may be better off buying a pump if you plan on a splitter. The 2305 is a bit low on flow for that application. I haven't used a splitter that was hooked to power beyond, but word on this board is that you need 8GPM or so to keep from getting bored waiting for the wood to split.
Cliff
   / Power beyond kit for 2305? #4
If you buy a Woods backhoe, it comes with everything needed to get the hoses to the rear.
Thanks for the info about the splitter. I'll keep that in mind, I wasn't thinking about flow but if it's too slow off the tractor hydraulics it might not be very useful.
And I am thinking about a woods BH6000. I've been looking on-line at Wellensteins and Woods BH's and the woods seem a little more rugged and capable on the surface.
   / Power beyond kit for 2305? #6
I'm fine with slow, so still looking to know if there is a 'power beyond' kit for the 2305...bump.
   / Power beyond kit for 2305? #7
Checked with the dealer today - there is no PB kit for the 2210 or the 2305. Not enough GPM in the system.
2001 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W41X143155 (A57453)
2001 Ford Crown...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
2011 Komatsu GD655-5 Motor Grader, S/N 55088 C014007, PIN# KMTGD026P01055088, Turbo Diesel Engine, (A59076)
2011 Komatsu...
1298 (A58374)
1298 (A58374)
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
