Power Beyond Kit for 790?
   / Power Beyond Kit for 790? #31
Welcome to TBN:D
If all you want is to run a logsplitter, then you need the PowerBeyond kit for your tractor. It will cost about $250 from JD, and you could install it yourself in a couple hours.
I have installed the kit but it will not extend/retract the cylinder. I have pressure (loosened a fitting) but I assume not enough for any function. The splitter is ok as it operated fine when hooked to another machine. It must be an issue with the 790. Any ideas?
   / Power Beyond Kit for 790? #32
Try reversing the lines your 790 should have no trouble operating a logsplitter.
   / Power Beyond Kit for 790? #33
Could be that the tractor is open center and the log splitter is closed center.
   / Power Beyond Kit for 790? #34
The tractor is Open Center, is the splitter valve was set for Closed Center then the system would go into relief and the engine would lug down quite a bit.
KING KUTTER 5' DISC BLADE W/ 1PT HITCH (A52708)
KING KUTTER 5'...
Toro Workman HD Utility Cart (A56857)
Toro Workman HD...
2005 International 7600 Dump Truck, VIN # 1HTWYAHT15J055083 (A57453)
2005 International...
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
Case Skid Steer Backhoe Attachment, S/N 391998, 20" General Purpose Bucket, Asset# 71 (A59076)
Case Skid Steer...
CASE MXM 190 (A58214)
