MadReferee
Elite Member, Rest in Peace
- Joined
- Apr 28, 2003
- Messages
- 3,741
- Location
- New Hampshire
- Tractor
- Kubota B2710, IH TD6-62 dozer with Drott 4n1 bucket loader
What you are calling a gismo is in fact the loader spool valve.kwolfe said:OK, now moving back to confused. Let me try this. When I installed the loader, I ran three lines (in, out, PB) from the hydro block (above left rear tire) under the tractor and into the gismo (tech term) that the loader control joystick comes out of. All three lines go into this thing. In that joystick gism there are 3 valves (correct?). These control the flow of hydro fluid depending on how I move the stick. There are four lines that come from the gismo that go to the loader. I am assuming that two (in & out) for each arm cylinder. What about the dump cylinder (only one)?
Your loader valve has 2 spools, in other words it has 2 functions. One spool controls the raise/lower cylinders and the other spool controls the bucket curl/dump cylinders. If there are 2 cylinders for that spool function, which most tractors have, then those 2 cylinders will be connected in parallel. The cylinders connected to one spool are independent of the cylinders connected to the other spool.
Each spool has 2 work ports These work ports connect to the cylinders for that function. Depending on the direction of the lever, one work port will be applying pressure to the cylinders and the other work port will be exhausting fluid from the cylinders.
The loader valve itself has 3 ports, inlet, outlet (aka return to tank), and power beyond. The loader valve is connected in series with the hydraulic pump, 3pt and tank. The series circuit flow enters the valve at the inlet and exits via the power beyond port. The return to tank port is used for exhaust fluid from the work ports.
