Power Flow on John Deere 455 with 48 inch deck
   / Power Flow on John Deere 455 with 48 inch deck #1
caseyvand
Dunvegan, Ontario, Canada
Hi I'm looking for some information on Power Flow blowers. Does the same Power Flow unit on a JD 455 fit the 48 and 54 inch mower deck? Does anyone know the model number? Are the 48 and 54 inch decks on JD 345 similar to the JD 455?
Thanks.......Casey
   / Power Flow on John Deere 455 with 48 inch deck #2
I saved myself the grief of ordering the wrong parts a few months ago by providing the dealer with the deck id numbers and the mower id numbers and left it to him to figure out. You do have to trim some of the plastic stuff to fit, easily done with a pair of heavy sheetmetal shears.
Thanks for the information....I'll proceed with caution. I've come to realize there are many different models. Ithought this would be eas
Thanks.....Casey
   / Power Flow on John Deere 455 with 48 inch deck #4
to my knowledge the 2 are the same, I have both decks, so will look, I have a power flow, there were 2 styles offered. If you look at a used one, look at the bottom of the blower, they wear our from rubbing on the ground. there are blower units on Kijiji also ..
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2017 Toro Workman HDX Diesel Utility Cart (A59228)
2017 Toro Workman...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
