power shift problem
/ power shift problem #1
runningbird
Gisela, AZ
yanmar 1110d ,fx28d
I have a FX22D that has developed a problem. The tractor can be running fine when all at once it stops moving. If you rev up the motor it may start again but it moves slowly and shifts are weak. Does not matter what gear you are in or if 4wd is engaged. I have cleaned the screen and put on a new hyd. Filter. Any ideas?
Thanks,
Mark
/ power shift problem #2
When the tractor stops moving does the pto still turn? If so, you are losing drive in the powershift transmission. If the pto also stops, bad clutch.
pto works fine in all speeds when the tractor quits. So then the question is how do you find the problem with the power shift trans. And thanks for the help.
/ power shift problem #4
Have you checked the delay relief valve springs ?
no I have not checked this, what and where is it? I do not have a parts diagram. I have been looking for one but have been told it may not be available for the FX22d.
thanks,
Mark
/ power shift problem #6
They are in stock. If you send me an email I will send you the diagram from the parts manual.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
sent you my email address. thanks Mark
Thanks all,
It was the spring Buppie mentioned. It was broke in to 6-8 pieces. Now to find a spring, hard part will be to match one up when mine is in pieces.
Thanks again,
Mark
/ power shift problem #9
Common problem, easy fix, IF you can find the parts. I guess it's become increasingly difficult to locate springs for any powershift.
/ power shift problem #11
Sorry, I probably misinterpreted his question. I took
As asking for the manual, not the spring. We have the manual but not the spring.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
/ power shift problem #12
What kind of spring are we talking about, pull, compression, torsion, what size, any pictures? Hardware stores and HD have all kinds of generic springs that can be easily modified.
/ power shift problem #13
Norm,
Reading comprehension.
/ power shift problem #16
All you have to do is stretch a correctly sized "pull" spring and you have a compression spring. Been making them for years.
/ power shift problem #17
Lets see if we can't help him get a spring.Sure would hate it if he goes BENKOHN on us:confused:Don't wish that on anyone and we sure would not want to have to go through that again.Couldn't help it:p.No offence to you and Just joking Runningbird :)
got a spring on order. thanks everyone!
/ power shift problem #19
Out of curiosity, did you have to call 150+ dealers, risk your reputation of "excellence" and face family belittlement before you found one? ;)
Couldn't help myself (a little BENKOHN thread humor..if you don't get it, don't worry, it's not aimed at you).
For Ben's sake and anyone else who mightl be using the TBN "search" function concerning this problem in the future, can you post where you found the spring?
Fredricks carries the spring, it should be here on tuesday.
