Power Shuttle operation and engine RPM?
   / Power Shuttle operation and engine RPM?
joes_427_vette said:
By the way... Keep the heavy snowfall on your side of the state. I just mounted a 5' western hydroturn plow on my 4110 John Deere. I don't believe it has the capacity for wet heavy drifts.
I hope to keep all the snow in my area. Milwaukee area has not seen real heavy snow in 15 years. I miss the snow :(
Bob
   / Power Shuttle operation and engine RPM? #12
Doc_Bob said:
Jim, you have a switch???? Wow, sounds very cool. Nothing like that on my TN.
So you can use your PS at 2200 rpm? Good to hear. If you can post a pic of your switch, that would be nice.
Bob
Here's the switch, if the pix comes through.
From the EHSS manual: "The EHSS transmission has two hydraulically operated clutch packs that drive the forward and reverse gears. The hydraulic clutch packs operate independently of the PTO system. Shifting the shuttle control lever to the neutral position stops the [forward] travel of the tractor while the PTO continues to operate; therefore the tractor has live power take-off.
The EHSS hydraulic system consists of an oil reservoir, oil strainer with six bar magnets, oil filter, pump, control valve, shuttle clutches, control levers and linkage. The oil reservoir strainer with magnets, oil filter and inlet tube are common with the 3-point lift system."
It sounds complex and probably is pricey to fix, but it operates like Joe 427 says - makes you look like a pro. Similar to Deere backhoes I've run: 410 and 310. The switch just makes the engagement happen quicker or more slowly. I don't think the actual clutching is done with plates, more like hydraulic lockup rather than discs. That's what the section schematic looks like, anyway.
I think it's got the advantages of the gear transmission with some of the ease of reversing the hydros have. Very happy with it.
Jim
We do NOT accept credit cards as payment. (A57148)
We do NOT accept...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2006 Chevrolet Impala Sedan (A54815)
2006 Chevrolet...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
