Power shuttle problem.....need help please
/ Power shuttle problem.....need help please #1
sampsue
Summerville, SC
Challenger MT455B, JD 2510, Vermeer Trencher
Hello, I have a Challenger MT455B 4x4 with the 8x8 gearbox. The tractor will start fine but will only move if the Differential is locked. When in 2wd and/or 4x4 it will not move fwd or rev and the indicator arrows do not light up or blink. There doesn't seem to be a blinking error code as far as I can tell. Also, with the tractor in neutral, 2wd and rear diff unlocked the green 4x4 symbol lights up on the dash if im pressing the brake pedals. The fuses are good, and I've cleaned and played with all the connections. After reading many post about the power shuttle I replaced the Bottom of Clutch switch but that didn't help. I'm trying to learn as much as I can cause I hate having to trailer it to the dealer for obvious reasons. I do have the factory repair manual and I'm making my way through it. If anyone has had this problem or can assist in any way I would greatly appreciate it. Thank you !
Jonny
/ Power shuttle problem.....need help please #2
For the 4x4 symbol when the brakes pedals are pressed, I think this is normal. The tractor engages 4x4 when braking for more stopping power. My JD6415 does this.
OK...never noticed that. Thought it might have been a clue.
Thanks
Jonny
2016 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 MACK CXU613...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
2014 Generac QT04854 Anax 48kW Natural Gas Generator (A61572)
2014 Generac...
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
17601CFL (A61572)
17601CFL (A61572)
(1) UNUSED 12.4-24 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 12.4-24...
