Yep. I rented a Porter Cable, which looks similar to the Aleko referenced in the OP. Coupled with the PC vac, and you have a real sanding machine. Weight seems to be about 1/2 that of the Aleko unit. I did an entire house in less than a day, and it did a GREAT job. You DO have to keep it moving, as it will sand right on thru the tape if you don't. Rental on it was about 50/day if I recall.....money well spent, if you ask me.
Someone mentioned corners....it does them with no problem...the most you might have to do is run a hand pole sander in the very corner a time or two....nearly nothing. And most of the dust was confined to the vac....not 100%....but I'd say 95%.
I later bought a far cheaper sander that was supposed to operate off the vacuum of a shop vac, and was very disappointed in it....nothing at all like the power head on the PC. Got rid of it in short order.
