Practice Removing Your FEL
   / Practice Removing Your FEL #71
Doesn't make any sense. When the loader valve is in "neutral" that is just like the loader being removed. Fluid has to go somewhere when you are not actuating any cylinders.
Okay then why do the manuals state that ... can someone else review the manuals for different model loaders like Kubota, Kioti, John Deere, Mahindra to compare. Sure hate to remove mine and cause damage.
I really thought the idea behind todays loaders was to take them on and off as need be.
   / Practice Removing Your FEL #72
I know that my Kubota does not require this. I wonder what is different. I have no doubt the manuals state what you are saying. Just curious why they are different.
Wondering out loud. Are these directions for removing the system, or just removing the FEL? They seemed rather unclear to me.
   / Practice Removing Your FEL #74
I just also read this in the manual for the FEL ... Power beyond kit is provided to relieve excessive pressure on the loader control valve when other implements are used while the loader is still attached to the tractor.
So ... it is saying that the Power beyond kit is used both when the loader is on or off. If thats the case why then was it not standard to come equiped with the Power beyond Kit?
I just emailed my contact at Branson for an explaination ....
   / Practice Removing Your FEL #75
Well I'm thinking because it says "When the Loader hydraulics are disconnected from the tractor" that would mean when you use the QD to unplug the loader ...
   / Practice Removing Your FEL #76
I think it is a terminology issue. As someone else stated, it sounds more like directions for completely removing it.
The flow should be: pump--->loader valve--->3ph--->tank
So if the line between the pump and loader valve had a quick disconnect in it, you could not just disconnect it.
In my case, this line does not have a quick disconnect. It is threaded on to the loader valve, and the valve stays behind when the loader is removed. The lines that you disconnect are the 4 that go to the cylinders.
Perhaps that is the difference. When you remove your loader, does the valve stay behind?
   / Practice Removing Your FEL #77
I have two tractors and two loaders and each manual says the same thing ... one is on a Montana and one on a Branson ... I quess its a Korean thing??
I've been watching this thread for a while and thinking I needed to give it a try. As I have a Korean tractor that came with a FEL installed (LS S3010) I got a little concerned after reading about your situation. Just looked at the instructions for removing and mounting mine and all they say is disconnect and connect the quick connect hydraulic couplers.
   / Practice Removing Your FEL #78
On my 2310 (M-F), disconnecting the loader is simply unplugging the lines... BUT, the valve does stay on the tractor.
On the backhoe, however, the valve stays with the BH, and a return line has to be re-connected "to avoid serious damage to the hydraulic system...."
Sounds like maybe it is whether the valve stays with the tractor or not is the key, as wvpolekat suggested.
   / Practice Removing Your FEL #79
Both mine are cab tractors ... obviously the Joystick stays in the cab and the lines are all QD couplers on the loader valve. Perhaps it is terminology and I am interputing it wrong. Either way I have an email into the Branson rep awaiting an answer.
I agree with what others have said. Makes no sense ...
   / Practice Removing Your FEL #80
When I took delivery of my Kubota M8540, I noticed a u-shaped hydraulic line in the toolbox. I asked what this was and the mechanic said it came off of the tractor when the FEL was installed.
It is basically a return line from the supply (pressure) side to the return side. When no valves are installed, it completes the loop. When you install a FEL, this is where you tap into the system.
There is a BIG sticker down near my FEL hydraulic valve (not joystick, but valve) that states you must re-install the u-shaped line if the FEL valve is removed... and NOT simply cap the lines. This makes perfect sense.
Anyway, unplugging the the QD couplers to remove the FEL does not remove the FEL valve. (On my Kubota anyway. I imagine on most Kubotas and on most other brands that have QDs.) The joystick in neutral allows the FEL valve to let fluid flow and return. This is the same whether the FEL is installed or not.
Now, if you tap into the system and remove the FEL valve, you have to provide the return yourself. In my case, I have the original line handy.
The main reason I know this is because I recently installed a 3rd function valve myself. To do this, you have to tap into the hydraulic system and re-route the pass-thru. (This is in addition to other things of course.) Instead of the return from the FEL valve going back to the main return, it goes into the supply of the 3rd function valve. Then the return from the 3rd function valve goes back to the main return. (Or vice-versa, I don't remeber. The 3rd function valve may be first, but the point is valid though.)
When all valves in the system are in neutral, fluid freely flows throughout the entire system. Nothing is blocked. When one valve in the system is opened, fluid is routed to the implement (cylinder, pump, etc.). When the system GPM exceeds the implement the bypass is used.
Deere 331G (A53317)
Deere 331G (A53317)
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A55973)
2012 Chevrolet...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
