Pre drilled holes? In bucket
   / Pre drilled holes? In bucket #11
The 6 lower holes are for a bolt on cutting edge/wear bar.
is that what there for...thank you. ive been wondering what there for.
I even emailed Kioti a few days ago. havnt heard back from them yet.
But now i know :) :)
   / Pre drilled holes? In bucket #12
My toothbar slides over the bucket cutting edge and is held in place by 2 bolts (one on each side of the bucket).
I can install or remove it in minutes.
   / Pre drilled holes? In bucket #13
my bucket sides are 3/16" steel...14 gauge is awfully thin
Well, I admit I estimated but 12 gauge is pretty close to 1/8 inch. I can measure mine next time I am near the tractor but I'd be surprised at 3/16ths. However, I've been wrong before!:laughing:
I did drill the toothbar holes on my CK20 bucket and those were certainly not hard to do with a battery powered drill.
   / Pre drilled holes? In bucket #14
i measured mine with a digital thickness device when i was designing a trailer moving device.
   / Pre drilled holes? In bucket #15
Wait until you have the tooth bar. Most of them have a fixed bolt and one that has a slot type attachment. If you locate the holes properly, you can loosen the bolt in the slot one and flip up the tooth bar for backstabbing with the tooth bar out of the way.
Thanks so much all yet once again for all the info. I will just wait. Im off to work fora few hrs n when I gethome the new dk50 should b sittin in the pole barn. Rainin or not im gettina lil seat time! Pack here I come. Lol
   / Pre drilled holes? In bucket #17
The holes in the side of the buckets are used to attach the bucket to the pallet for shipping. Before you ask why are they in both side then? Because when the end plate are cut and drilled they are the same and it doesn't matter what side they get welded to.;)
Dealer had a tooth bar in stock so they r just gona pre drill it for wat a nice guy. Been a good buyin process with Hoover Tractors.
   / Pre drilled holes? In bucket #19
...... and my tooth bar just slips over the cutting edge and is held on with four "set screws", no holes to drill.
   / Pre drilled holes? In bucket #20
The holes in cutting edge are for extra bolt on cutting edge, as stated earlier, but also for individual teeth to be bolted on. Holes in side of the bucket are for side wear bars to bolt on. At least this is on the Bobcat loader buckets.
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
VINTAGE JOHNSON OUTBOARD MOTOR (A58374)
VINTAGE JOHNSON...
2015 Komatsu PC490LC-11 Hydraulic Excavator, S/N A42603, PIN# KMTPC251HFWA42603, Turbo Diesel (A59076)
2015 Komatsu...
2007 GALYEAN 130BBL VAC TRAILER (A58214)
2007 GALYEAN...
1997 Moxy MT30 Haul Truck (A55272)
1997 Moxy MT30...
