Pre drilled holes? In bucket
   / Pre drilled holes? In bucket #21
Mine LS bucket has no holes anywhere. It is water tight. So was my V3 loader on my graymarket Yanmar until I drilled the 2 holes for the tooth bar in the 1/4" thick side plates
   / Pre drilled holes? In bucket #22
The sides of my 1231 loader bucket are thicker than ,most
I drilled throw hard edge for cutting edg on my bucket an that wa not fun
Pilot hole all the way
Joel
   / Pre drilled holes? In bucket #23
Joel, did you use cutting oil when drilling your cutting edge? I had adapted a snow blade to my 3054 before I got the blower and had to drill two 3/4" holes in the cutting edge so as to mount the push frame. I used a 1/4" pilot drill and then the 3/4" bit using cutting oil with both and had no problem punching the holes :thumbsup:
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2017 Komatsu PC490-11 Hydraulic Excavator, S/N A41596, PIN# KMTPC251JHWA41596, Turbo Diesel Engine, (A59076)
2017 Komatsu...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56435)
2023 Kubota Z412KW...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
2018 Caterpillar 287D Compact Track Loader Skid Steer (A56857)
2018 Caterpillar...
2015 International Bucket Truck (A55973)
2015 International...
