Pre-fab trusses for shed style shop?
   / Pre-fab trusses for shed style shop?
Thanks guys. Tons of great info here. Lots of things to consider.
As far as snow, not an issue. We get snow accumulation every 4 or 5 years but rarely more than a few inches. Sitting on the front porch of the cabin right now and it’s 65, windy and bats are out.
As far as birds in the trusses, I will likely put a ceiling in.
As far as attic storage I’ve already written that off.
As far as steel trusses, my nephew recently built a 40x100 foot barn with metal trusses from a place in Georgia and he says they are already torqued and twisted. Maybe he gave the wrong specs but his experience has put me off of that path until I can do some more research.
Agree about over hang. In my opinion more is better.
A little concerned about the height at the front as someone mentioned.
What is the lowest slope you can use in an area where snow is not an issue?
   / Pre-fab trusses for shed style shop? #22
I am in the process of planning a shop for down on my property. I have no idea if this will become a reality as it is still early in the planning stage. What I want/need is a 30x40 3 bay shop.
I have had a site prep guy out and he says location is fine and won't need too much earth moving at all.
I will be milling my own lumber. I will be doing most of the work myself. It will be on a concrete slab (concrete contractor). It will be stick built. Probably on a low cinder block knee wall. 5v crimp metal roof. Looking for about 12' of height clearance inside.
When I built my log cabin kit 20 years ago it came with prefab wooden scissor trusses for a single peak roof. They were no problem to install.
However, I would prefer that my shop have a shed roof that slopes to the back (where drainage is best.) I would prefer to have a clear internal space with no posts/columns.
My question is this: Can pre-fab shed type trusses be purchased? Any guesses on cost? Is it feasible to make your own? Any ideas much appreciated.
Are you wanting a single slope roof? If so, you could frame out of i joist or dimensional lumber or a floor type girder truss by building a knee wall on the high side wall.
You would just need to have a girder running perpendicular every so often depending on your spans.
   / Pre-fab trusses for shed style shop? #23
I find that odd. I have a 40' x 95' barn and while it's not exactly a truss, it does have a clear span of 40' with 20' spacing. It uses "I-beam" for both columns and rafters spaced every 20' with purlins in between.
Depends on the roof material. If it's fiberglass shingles, manufacturers say no less than a 3 in 12. If it's steel sheet, I believe you can go as low as 1 in 12, mine is 2 in 12 and I personally wouldn't go any less.
   / Pre-fab trusses for shed style shop? #24
Are you prepared for it to be destroyed by the changing climate?
I HAD a 40' wide Versatube carport, very sturdy, in northeast Mississippi over 10yrs old. Lasted through several multi-inch snowfalls, one up to 4". But the AVERAGE is only 0.7"/yr linky
Last year we got a snowstorm, followed by an icestorm. Crashed to the ground. As did a lot of structures in the area. There were Gas station canopies down ALL over the area.
I'm not planning on ignoring structural concerns. Just probably won't build it to take Buffalo, New York type snow loads. Plus, I'm still in the 'idea' phase here. No hard plans yet.
We have friends in the northern part of the delta. They had a covered pergola type thing in their back yard and the snow collapsed it, probably in the same storm you're talking about.
When I was kid we lived in Clarksdale, just below Memphis. We got snow there regularly.
Where my cabin is, any snow is pretty rare. In the last 30 years I can remember maybe four or five times it has covered the ground there. The last big snow we had there was maybe 5 or 6 years ago and even my 40x20 tractor shed held up fine and it only has a 1:12 slope on it and it was built by someone with so-so skills and virtually no prior experience in that type of construction....although I did look over snow and wind load stuff before I built it. ;-)
Also, someone mentioned inspections and using my own (ungraded) lumber. I'm not expecting to have to deal with any of that. Typically not a problem in this area with add-on buildings, shops, barns, sheds etc. We did have to have a permit and inspections when we built the cabin of course. The only issue would be if the power company requires a permit or inspection to hook it up to the pole. If that's the case then that's a whole other can or worms and might be a deal breaker.
   / Pre-fab trusses for shed style shop? #27
Here in TN, our local power co-op requires an electrical permit to install a meter. If you daisy chain from house, they could care less. When installing a meter to a structure they require the meter box, 2 8' ground rods driven vertically with 6ga solid copper wire (not stranded), and a distribution panel with at least 3 circuits: an out door light, an indoor light, and an outlet. All installed to code prior to meter connection. The only exception is a well pump meter which is just a weather tight CB box below the meter (no lights). I have one of those, too.
   / Pre-fab trusses for shed style shop? #28
when I build my 30x40 shop I went with premade trusses. The best part was the truss company delivered them and put them up on the roof. We just had to move them to where they went. I also had them design into the trusses, storage space....so some of the members are bigger than if I hadn't had them design in storage space.
I suspect if I have them put in a meter our requirements here would be the same or similar. The county goes by what they call the International Building code. At least they did 20 years ago. It almost derailed the construction of my cabin as they make no provision for things like hunting cabins etc. So unless you knew people then you had to follow the code to the letter. We 'knew' a few people and got some slack here and there thank goodness. If you _really_ knew the right people you could get away with just about anything. Seen it first hand.
I don't mean to rant too much but to put things in perspective, when we built the cabin there was a house a mile or so down the road without running water. It is among the poorest counties in a poor state and is rife with corruption at the county level. To have "international" building codes is a bit of a joke and many of the requirements, especially for a hunting cabin, were simply a joke.
So if at all possible I will daisy chain from the house. I know an electrician who will guide the work that I am able to do and I will pay him to do the rest. It will be done properly and safely.
As an aside, we had to drive in the two copper ground rods for the cabin as well. We have a few inches of decent top soil, a few feet of clay and then rocks or very hard crumbly material. I got one of the eight foot rods down about 5 feet and it wasn't going in any further. I asked a local fellow how he did his and he said he "drove them in with a hacksaw". I thought that was very funny. So both of mine went down about 5 feet and then got lopped off. Not sure it was wise but we've had zero problems in 20 years.
There is some space in the trusses of our cabin. Not what I would call an attic but still usable storage space. I put down some ply-wood for reinforcement. I'm pretty sure the truss spec says not to put anything heavy up there and we don't.
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2018 Wacker Neuson LTV6 (A53316)
2018 Wacker Neuson...
New/Unused Quick Attach Auger with Three Bits (A54865)
New/Unused Quick...
2121 (A51244)
2121 (A51244)
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55302)
NEW 2025 Load...
