Premium or regular unleaded
   / Premium or regular unleaded #21
Not so true anymore.... our 2013 Impala is 11.5:1 and recommended fuel is 87 octane.
Yes, that's why I said, In 99% of engines made, the compression ratio determines the octane of fuel required.
I have seen Chevrolet say, premium fuel is recommended, but not required, in SS impala's.
There are some things engineers are doing to get around the detonation issue.
I read about a new engine being developed, which will now have variable compression. I'm not going to be volunteering my money, to do testing on that for them. But, I suspect they will get there.
   / Premium or regular unleaded #22
I've been able to purchase 87 Octane Ethanol Free gas just about anywhere around here but I know of only one station with 89 Octane and 91 Octane ethanol free and its a good drive to it. I try and go once a year and get 5 gallons of 91 Ethanol Free for my small engines (weedeater, chainsaws, leaf blower, tiller)
and I can tell a difference occassionally but not always. Last time I really gave my little Mantis tiller (aka: Echo, Shindaiwa) a good workout I hadn't picked up any hi-octane ethanol-free gas and used regular ethanol free because I had it on hand. It was a hot day and I could hear the engine knocking every time I pulled back against the tines. As I realized what was happening I stopped and parked the tiller; emptied one of my 5 gallon cans into my Scag and Linhai and made the drive to the only station for miles for some 91 Octane Ethanol-Free gasoline and made a new batch of 50:1 using it. Dumped the remaining tank and filled up with the hi-octane mix. No more knocking (pre-ignition) when pulling back under load.
If it were nearby I'd use hi-octane ethanol free in my Scag while the prices are down. Back when it was over $4/gal it was touch to tank up. As long as they are lower I use regular 87 Octane in my pickup and average 19.8 mpg. With 10% ethanol gas I get 16 mpg average. Cost per mile is about the same so why not get the ethanol-free gas since its available?
   / Premium or regular unleaded #23
Non-alcohol gas is not convenient for me. Long drive and +$.40. I go through 100 GL/year for small engines that I get in my 50 GL transfer tank. Since I started adding Staybil 360 Marine my problems disappeared. As a test last winter I did not drain anything but filled to the top. When starting up this spring everything clicked right off as if it had been running all that time. Due to tree blow downs and power outages I need my chain saws, pull motor, (old lawn mower used to tow a trailer) and gen sets ready to go. Cars and trucks are made/tuned to run on low octane E10. Never seen E15 around here.
Ron
   / Premium or regular unleaded #24
That's a 40+ year old tractor.
It was designed to run on regular, low octane gas. So that's what you should use. If you're worried about ethanol related problems, try and find ethanol free low octane gas. Personally, I've never, ever, had any ethanol related issues in anything I've ever owned, with the only exception being one fuel line in one chainsaw that turned to mush one time. And I can't prove it was the ethanol that did it.
Exact same results here.I tried E free one time, the saws would not run right with it, i didn't have the time to adjust the settings, dumped it, put the E back in & they were happy:confused3:
Ronnie
   / Premium or regular unleaded #26
Regular is the way to go.
I was using E10 for years as it was 1 cent cheaper at the pump and 'environmentally friendly'... what a CROCK! I switched to regular and immediately got better 'mileage'. Then I received a new RSL (Australian Veterans Organisation, like your 'Legion') members card that knocked 6 cents off regular petrol @ a specific provider. Woo HOO!
Wow! And then you can get another 4 cents off using a Coles or Woolies fuel discount docket (Shell and Caltex respectively) providing it covers your specific retailer. This should save you $10s every year. A few years ago both supermarket chains were offering discounts of up to 45 cents a litre if you spent x dollars in their shop in one transaction (can't remember the amount but it wasn't that high and within most people's weekly grocery shopping amount - just buy extra discounted soft drinks, lollies and other basic food groups to make up the total if you didn't have the average 2.2 children that week). Then in 2013 the Australian Competition and Consumer Commisioner stepped in and forced the chains to drop the incentive while they conducted an investigation into whether fuel saving offers were causing a substantial lessening of competition in markets for the retail sale of fuel. Guess they're still investigating?
   / Premium or regular unleaded #27
Wow! And then you can get another 4 cents off using a Coles or Woolies fuel discount docket (Shell and Caltex respectively)...
The discount is for "United" servos only... which is great for me as we've only got a United & a BP in our wee town. United also offers the 6 cents off to RACT members. Nothing but IGAs outside of the Big Smokes anyway so I can't gather their dockets even if I wanted to.
   / Premium or regular unleaded #28
Gotta toss in on this. Sat by the sidelines for years on the E10 or not question. After hardened rubber parts in non-new small engines and marine engines, the alcohol apparently does dry out rubber not suited for it. Truck is flex fuel rated and tractors are diesels. Latest instance was dried out diaphragm in fuel pump of Weed eater string trimmer.....besides the melted fuel lines.
   / Premium or regular unleaded #29
I read about a new engine being developed, which will now have variable compression. I'm not going to be volunteering my money, to do testing on that for them. But, I suspect they will get there.[/QUOTE
It's because the engine is direct injection instead of port injection.a gasser with Diesel thermal efficiency without glow plugs, particulate filter, urea, turbo and waxed up fuel filters.
   / Premium or regular unleaded #30
I run E10 87 octane in all of my small gas engines, I do add stabilizer to my 50:1 mix and add stabilizer to the fuel tanks on the mower and generator over the winter. I also keep the tanks topped up to minimize condensation. I've not had any problems with any of my gas equipment due to ethanol in the gas with these minor precautionary actions.
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
Online Buyers Premium (A47477)
Online Buyers...
AUCTION STARTS HERE @ 9AM (A52705)
AUCTION STARTS...
2005 FREIGHTLINER COLUMBIA SLEEPER (A54313)
2005 FREIGHTLINER...
2008 Hitachi PC228 (A47477)
2008 Hitachi PC228...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
