buickanddeere
Super Member
Silicon grease on the door seals will keep the doors or trunk from freezing shut.
Edit - also get a good quality silicone spray (I use a silicone/teflon Dupont one, from Lowes) and spray ALL the rubber seals - doors, hood, trunk. Goes a long way towards preventing doors etc freezing shut, and helps preserve the seals.
Rgds, D.
I am going to try this suggestion. My truck doors will freeze shut sometimes in the winter.
To the OP, I would get a timer to use with the engine block heater. My truck's heater pulls 1500 watts and the truck needed three hours to heat the block. Power used to cost me 10 cent a KWH, so it was almost 50 cents a night to warm up the truck, which does not sound like much, but if you did this 30 days a month that is 15 dollars which at the time was about 13% of my power bill. If you did not use the timer, well, it is a heck of a lot more money. Now, I only plugged in the truck when I knew I would be driving in the morning.
I don't use the block heater now that I use a 0wx40 oil. I do miss the block heater on cold mornings because the engine would have enough heat to start warming up the cab right after engine start instead of 5-10 minutes/miles down the road.
The suggestion to have a survival kit in the car is a great idea and don't forget to include matches and candles along with blankets, extra clothes and food. I always travel with food and WATER, especially water. I assume up in the Great White Nawth there would be snow on the ground and thus water but if not, carry some.
Later,
Dan
$15 is a mere pittance and about two gallons of fuel. How many gallons of fuel of burned by vehicles idling to warm up?
Anyone mention kitty litter? for traction if you get stuck? I normally just keep a bag of pea gravel in the back of the car as we don't have indoor cats and I can always use the gravel.
I normally have the gravel, first aid kit, hand warmers, flare, extra hat gloves and coat for me and the kiddo, wool blanket, a few breakfast bars, two bottles of water, oil, etc.
also harbor fright has a breaker bar that is compact. I have used it to change tires when I get a flat and it works great. I don't see it listed on the website anymore.
2x on the silicone, going to do this in Ohio too and see how it works, and a timer is good idea too. Maybe try 4 hours prior, for starters and see how it goes. Along with the lock lube and a good emergency kit I'm putting together, should be good to go. Oh, and some moose repellent![]()
