Flatheadyoungin
Veteran Member
Well, I called to order the unloader valve for both machines.......we'll see......I'll post my results here........
thanks, again!
BTW, the guy on the other end of the phone was very helpful and friendly!
thanks, again!
jelc said:Glad you figured out the problem with your Karcher pressure cleaner... For anyone out there with a K2400 model with the same symptom, there is a well kown problem - the unloader valve came out of the factory with unsufficient grease, and the simple (and cheap) cure is to either grease the valve and be ready to repeat that if it does not work after a while, or get an upgraded valve from a supplier like West Michigan Power Cleaning Systems. See below for the K2400 unloader valve:
What to do when your K-2400 pressure washer loses pressure :: West Michigan Power Cleaning Systems
JLC
