Pressure washing
   / Pressure washing #11
</font><font color="blue" class="small">( That sounds a lot like my pressure washer it has a comet pump and is belt driven,did you buy yours in Florida?Thats where mine came from.
USA Pressure Systems INC. )</font>
Yep, that's it. Thanks for the link-- satisfies Polecat's request for a picture. USA Pressure Washers was located in the airport industrial park in Fort Pierce, about 45 miles South of Palm Bay, when I bought mine. Port St. Lucie is only 10 miles from that airport, so I just drove up there, told them what I wanted, and they built it. I knew they had moved to another facility several years ago, but I didn't know where until you posted the link.
I don't have a lot of luck with small gas engines, even Hondas, so what I really wanted was a washer with an electric motor. At that time, we used it for several hours a day, and always in the same location. The lower noise level would have been nice, too. The problem was that a washer of that size would, according to the builders, require a 10 HP motor, which would have been 3 phase -- and we didn't have 3 phase available, nor was I willing to buy a converter. So, I took it with the 13 HP Honda. Despite my fears, the only problems we have had are with the uinloader valve (almost annually) and some seals letting water get into the oil in the pump. 14 years and many, many hours of operation later, the Honda still starts on the first or second pull.
I love it. Just the other day, I brought it home, dialed back the pressure a bit, and used it to blast pine needles out of the overhead pool screen. Fortunately, our neighbor has removed the pine trees, so that's the last time I may have to do that! He never had any sympathy about the needles until he put up his own pool screen last year... /forums/images/graemlins/grin.gif
   / Pressure washing #12
<font color="blue"> but u r sposed to b one of the leaders round here!!! </font>
Crikey! No one told me! I better get my act together and start behaving! A leader? Heck, whenever I read those posts about people messing up the forum, I figure they're talking about me! They motivate me to stay on the straight and narrow for at least 4 hours or so, then I go off thread-hi-jackin' again, just like this post!
   / Pressure washing #13
</font><font color="blue" class="small">( <font color="blue"> Sometimes the cheapest deal is not the best deal, some people take a lifetime to learn that and will go to any expense to save a dollar. </font> )</font>
Hey TresCrows, it's not easy being Scottish. It's a genetic thing as far as money is concerned. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
My usual philosophy as far as buying tools and equipment is concerned is that if it's something I'm going to use a lot - I buy the best I can afford - but if it's something that is only going to be used a couple of times a year, I tend to buy a cheaper model. If I only use it a couple of times a year, I think that even a cheaper model should start and run 40 or fifty times before it craters but I DO like things to start and run.
I think I'll take your advice this time though and move up to one of their smaller commercial models with the Honda "GX" engine and CAT pump.
Thanks guys for the advice.
   / Pressure washing #14
ok heres a pic of my old beater...had it for bout 6 yrs now and it's paid 4 itself a hundred x pressure washin cement drives down in alabama....pid 300 4 it and got it used....buy high quality used....1/2 priceusually..jist start the engine and try it out b4 u buy it..also check the oil..handa is bar far the best engine i've ever owned but the briggs and tecumseh's r good ol stand bys..pull engine over slowly to see if its got good compression..if it's been outside u may have 2 take the flywheel/pullstart cowling off and clean the magnets and pickup coil frome the rust..wire brush or wheel on a porta drill works best /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Pressure washing
Thanks for the response, but I think that one CFM of air is actually more than a gallon of water, therefore the simple product of the cfm and psi versus gpm and psi may not be accurate.
Any thoughts on this?
   / Pressure washing #16
Where's the photo? G
   / Pressure washing #17
two ofem..had to go out and takem!!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
and its a 10hp briggs ic series with 3000psi
sorry bout that i was thinkin bout the 11hp Honda thats on our 6000 watt generator
   / Pressure washing #18
Your pressure washer looks dirty. /forums/images/graemlins/smirk.gif
As to the Thundergun vs a pressure washer, never used one so cannot say.
Polecat's unit looks pretty strong, that is a big jump up from the original post, course, we got guys with L class Kubotas on 2 acres so may as well have a 10 horse industrial washer too /forums/images/graemlins/crazy.gif. Why stop halfway, more is better right. /forums/images/graemlins/laugh.gif. J
   / Pressure washing #19
I've been following this post with a lot of interest .
I'm dumb as rocks about pressure washers .
I'd like a machine that can take care of siding and decks mostly . But I'm sure I'd find other uses as well /forums/images/graemlins/smile.gif
I don't want a machine that falls apart in a few years .
I don't mind forking over the money if it buys a quality piece of machinery . Basically I don't want to buy an under sized PW . But I also don't want to buy more than I really need .
Any suggestions as to a reliable make of PW would be very much appreciated . John
   / Pressure washing #20
</font><font color="blue" class="small">( I was looking in the Northern Tool catalogue at one with 2.5 gpm at 2600 psi, Comet pump and Honda 5 hp GC engine. )</font>
I have almost the same thing, but 2,000 psi at 3.0 gpm. Otherwise, it sounds identical.
Mine has been perfect for my needs, and I have had no trouble with it whatsoever. I paid $450. It was on sale for $500, and they had a 10% off offer for opening a charge account. I opened the account, got the discount, and haven't used the account since. /forums/images/graemlins/grin.gif
SnowRidge
New Bulk Lot Chain Slings (A53002)
New Bulk Lot Chain...
2013 Kia Soul Hatchback (A51694)
2013 Kia Soul...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
2010 L3 MEP-806B GENERATOR (A52576)
2010 L3 MEP-806B...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
