Price for culvert pipe
   / Price for culvert pipe #12
The weight of what is crossing it does not matter, the strength comes from the round shape and being buried the correct distance below grade.
$18 per foot sounds high for new culvert to me. The last plastic culvert I bought was 12" x 20' and was just under $100, with the smooth liner. About $5.00 per foot. The 24" should be just about twice as much.
I would start at $100 if it is lined, maybe $50 if it isn't.
I have carried it on the lumber rack on my F-150, well strapped down. OTOH, I was very picky about how that rack was mounted on the truck. The guy who did it wanted to put the bolts about 12" from the back of the bed. I insisted on as close to the rear as he could drill the holes.
I recently installed 300' of 18" plastic pipe. It was the ribbed-looking plastic pipe that was a smooth bore inside. I think they called it N12 or something like that. It was $10 per foot. It was real nice to work with. Once I finished digging my trench I was able to snap them in place fairly quickly.
   / Price for culvert pipe #13
make a habit of visiting your local culvert supply and getting to know the salesman.
I have a Kennedy culvert by me and you would be surprised what they throw away because very slight damage.
I have whole 20' lengths HDPE with chipped bells that I got for nearly 80% off. they range in size from 10 to 36" I always keep them around.
   / Price for culvert pipe #16
Any idea of what the weight is of a 24x20 HDPD pipe not lined? Can I put it on top of a Grand Cherokee with the factory roof rack?
I don't know if this will help any, but I handled 18" OD dual wall smooth bore N12 pipe recently and the 20' length was readily handled by two men. By myself, I could lift one end and move around while the other was on the ground. So I am thinking it was around 150-160 lbs or so.
I don't know if a factory roof rack has enough span between crossbars to really be stable with such a long heavy load. Normally racks can handle 100-120 lbs of centralized load. I'd worry a long, heavy, draggy load could really twist the heck out of the rack.
   / Price for culvert pipe #17
Here is the redneck method we use around here to transport 20' culverts when we don't have a 20' trailer. You need an open trailer (12' to 14') with side rails no higher than the tailgate of your pickup truck. Load as much of the culvert into the pickup bed as will fit, the rest of the pipe will extend out over the tailgate across the open space and into the trailer. It works, just don't make any real sharp turns.
   / Price for culvert pipe #18
You pay for diameter as well as length.
I paid about $300 for 18"x20', extra heavy duty.
That's what I paid also. Mine could be 18" or 20" in diameter; I can't remember for sure.
Obed
2014 Ag Spray Schaben Sidedresser (A57024)
2014 Ag Spray...
1990 TRAIL MASTER TRANSPORT TRAILER (A55745)
1990 TRAIL MASTER...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
