Prince 2 spool log splitter/ lifter valve
   / Prince 2 spool log splitter/ lifter valve #1
BethelHntr
Washington State
JD X300, Harry Ferguson TE20, 2013 Kioti DK 40 SE.Shuttle
I have a question on this valve and the detent function. 2 SPOOL 25 GPM PRINCE LOG SPLITTER/LIFTER VALVE
With the valve body and levers towards the operator it detents when pulled towards the operator or the push stroke, On single spool valves the detent is the retract function, Does this valve detent on the push stroke normally? Or does it push through the wood and return automatically? I need an explanation of how this valve works apparently. Thanks, BH.
   / Prince 2 spool log splitter/ lifter valve #2
https://www.youtube.com/watch?v=Z1SNl40HiQg
This video should explain the hose connections, and detent position.
A port connects to the base end of cyl
B port connects to rod end of cyl.
Detent is on the return stroke.
How you mount the valve is up to you.
The log lift spool is just another spring to center spool.
Thank You JJ
Thanks JJ
Portable Restroom (A54865)
Portable Restroom...
Miva Mini Excavator Attachment Set (A53316)
Miva Mini...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
16ft T/A Flatbed Trailer (A53424)
16ft T/A Flatbed...
2019 INTERNATIONAL RH613 SINGLE AXLE DAY CAB (A56129)
2019 INTERNATIONAL...
