OP
MChalkley
Elite Member
- Joined
- Mar 27, 2000
- Messages
- 3,198
- Location
- Eastern Virginia
- Tractor
- EarthForce EF-5 mini-TLB (2001)
Dan - <font color=blue>Mr. Moderator</font color=blue> Muhammad was hoping it would make me less opinionated - it didn't work... /w3tcompact/icons/laugh.gif
<font color=blue>Have you used the Pro Ears with a rotary cutter? Or anything else at RPM speeds?</font color=blue> Not yet, at least not under actual cutting conditions. I hooked the Ammbusher up and wound it up to full speed, just to see what it sounded like, and the Pro-Ears were just as effective on the noise it produces, but I didn't cut anything with it because I've already seen (heard, actually) that they handle impact noises quite well.
<font color=blue>Right now I cannot hear anyone in a car if they pull up behind me. Would you be able to hear someone drive up from behind you?</font color=blue> I think I would on my gravel drive, but it would depend on the surface, I expect. I do think I can say with some certainty that you'd be a lot more likely to hear a car with the Pro Ears than without.
<font color=blue>Did you get the Pro Ears Dimension 2 and have you tried to listen to the radio while running the tractor?</font color=blue> Yes and yes. The way it works is by simply introducing the sound from the radio into the earcup unprocessed. The Dimension 2 headset comes with a mono cord, which means it takes an audio source from a radio and feeds it into one earcup only. If you wanted to hear it in both ears, you'd need to buy a "Y" adapter. Or, if you wanted to hear a stereo FM radio source, you'd need a cord that adapts the stereo output jack to two mono jacks, one for each ear. You control the volume of the radio in the ear cup(s) with the radio's volume control. (I haven't used the Pro-Ears with an FM radio, but I have used them a fair bit with FRS radios.)
As I mentioned in an earlier post, I'm working on a big project all this week, so they'll really be getting a workout. I'll let you know how they do.
