Problems I should look out for in 5203 purchse?
   / Problems I should look out for in 5203 purchse? #1
Verticaltrx
VA
Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
I've been looking for a 40-50hp 2wd utility tractor and came across a nice looking Deere 5203, 2007 model with 300hrs. I haven't had a chance to drive the tractor or look it over beyond a quick glance. What kind of problems should I look out for in this series tractor? I've read quite a few accounts of trouble with the 3pt hitch. What kind of a price range would be considered good (just the basic tractor, no loader, accessories or remotes)?
Thanks for any input.
   / Problems I should look out for in 5203 purchse? #2
Is this the black painted engine or green? Seems like the lift issues were with the early models and not so common on the later models. The 2.9L engine has been around several years and in my opinion is solid.
I would figure $10k to $12k asking price and would shoot for $9k to $11k if buying.
It is the one with the black undercarriage, I think they switched midway through '07 but I don't recall exactly. Not worried about the engine, they have used the 2.9L since 80's and before that in a smaller displacement. I also think the transmission/rear end should be solid, it's the basically same as they've used since '92 when the 5000 series came out. The issue with the 3pt hitch is is only thing holding me up. This tractor will be used primarily for my business, so the 3pt will be used a lot, downtime is expensive, and the tractor will have to sit outside when on jobsites (rust seems to aggravate the issue from my research.) Seems like a good solid tractor other than this.
   / Problems I should look out for in 5203 purchse? #4
I have two 5403s and a 5203. I've had no issues with any of them, including the lift arm issue. I paid $11,000 for the 5203 with 170 hrs.
Sent from my Milestone X2 using TractorByNet
   / Problems I should look out for in 5203 purchse? #5
Have been around a bunch of these myself and cant speak to any three point issues, pretty good plane Jane tractor IMO and have held their value well in the used market.
   / Problems I should look out for in 5203 purchse? #6
Was hoping Kessler would chime in. There are a few others on this site using these models. The lift arm issues, if I recall correctly, were not major repair issues. At this point I would not hesitate to buy another.
Good to know. It's sometimes hard to judge how much of a problem some of these things really are.
2009 CHEVROLET C8500 CREW CAB FLATBED TRUCK (A59823)
2009 CHEVROLET...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
EXCAVATOR JACKHAMMER (A58214)
EXCAVATOR...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
