Problems on home built FEL
   / Problems on home built FEL #31
I haven't found a need yet to dump the bucket quickly, it just does it on it's own when full once it reaches the break over point. I would like it to just dump at the speed of the pump without me having to manually slow it down with the loader valve. I am going to try using the flow control valves to see if this will remedy the problem. Only issue with them is where to try and fit them in. Small tractor, small loader and short lines.:(
Many loaders have this regen function built into the control valve...
If you do not find quick dump necessary, fine, just mount the one way flow control on the rod side port then....restricting the return flow from the rod side...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
1997 CATERPILLAR 322BL EXCAVATOR (A52707)
1997 CATERPILLAR...
2021 CATERPILLAR 349 EXCAVATOR (A52707)
2021 CATERPILLAR...
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
