Project "Oliver Drill Resto"
/ Project "Oliver Drill Resto" #1
ENG18LT
Platinum Member
Syracuse and Warsaw, NY
Mahindra 5530 4wd
I went to check on a 10' cultipacker on craigslist today. Good thing I took extra cash. I did manage to get the packer, as well as an Oliver Superior grain drill. It is a model 64, serial number 64-4723. The unit has 17 rows, two large boxes on top, and a smaller (3"x3") box on the rear. Previous owner used it 3 years ago, then let it sit outside. It is going to need some PB Blaster, sanding and paint, and a couple tires. I am planning on using to plant a 5 acre food plot for wildlife. If anyone has manuals or knows where I might find copies please chime in. Here are some pictures of todays haul:
Enjoy! I look forward to your responses.
/ Project "Oliver Drill Resto" #2
Looks good. Sorry I don't know where to find a manual for it.
/ Project "Oliver Drill Resto" #3
Nice haul there!!! That drill looks to be in pretty good shape, very restorable if you wanted to go the whole 9 yds on it. Is there any rust down inside the boxes?? The packer looks nice too. You done good, my fellow CraigsList'er!!!
/ Project "Oliver Drill Resto" #4
Nice stuff. You did good.
A few years ago I restored an old Minneapolis Moline P3-6 grain drill (10 ft wide, 20 drops, single disc openers, 6" row spacing). Bought two of them from a neighbor for $275 and used parts from both to make one good operating drill (the other drill is a lawn ornament). Added about $300 in new parts. A fun project.
Drill restore-1.JPGDrill-1.JPGDrill-2.JPGDrill-3.JPGDrill--4.JPGDrill-5.jpgDrill-6.JPGDrill-hyd ram.JPG
Good luck
/ Project "Oliver Drill Resto" #5
Just out of curiousity , what is the difference between a planter and a drill ?
/ Project "Oliver Drill Resto" #6
You might be able to get a manual through your AGCO/Massey Ferguson dealer.
/ Project "Oliver Drill Resto" #7
Planters generally are used for larger size seeds (corn, soybeans, peas, beans etc) that are planted in widely spaced rows (1-3 ft). Grain drills are used for smaller size seeds (oats, wheat) that are planted with smaller row spacing (4-8").
Some grain drills, like mine, have grass seed boxes for planting smaller seeds (ryegrass, etc).
Both use some type of opener to form a furrow for the seed, some type of seed metering device, and some means to cover the seed and press it into contact with the soil.
Thanks for all three responses. I am heading out to our property with the drill this morning. I had to reposition the load on the trailer, it was too much tongue weight. The ride shouldn't be bad, a friend of mine is riding along.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=305897"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=305898"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=305899"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=305900"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=305901"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=305902"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=305903"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=305904"/>
Good luck
Nice job on the restoration. I am hoping to get mine cleaned up and functional over the summer.
/ Project "Oliver Drill Resto" #10
Thanks. The seed cups were pretty rusted. I got them apart.
Cleaned the loose rust off.
I coated the fluted feeds (black parts) with Gemplers Rust Converter to slow down the oxidation process.
I used cold galvanize spray coating on the seed cup housings (grey parts).
The galvanize coating on the boxes was rusted in spots so I coated the outside surfaces with the cold galvanize spray paint.
Good luck.
/ Project "Oliver Drill Resto" #13
I will have to look into this, thank you.
Your welcome.
I hope it works. I spent over an hour searching, and that's all I could find.
/ Project "Oliver Drill Resto" #14
Congrats on the purchase ENG. I have an old Massey Ferguson drill that I bought for plotting but have never used. It needs some work also but I may just sell it if I can ever find a buyer.
A planter plants seed one at a time at a metered rate, and has pretty exact spacing between seeds. A drill plants with more of a "controlled flow", and is normally used for grains such as wheat, oats, rye, etc. that do not need exact spacing.
Well I went out to the farm today and got the drill unloaded. It actually went a lot easier than I thought, the Mahindra picked it right up.
/ Project "Oliver Drill Resto" #16
Nice tractor:thumbsup:
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
(INOP) FORD 7710 TRACTOR (A60430)
(INOP) FORD 7710...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 1.5 Ton Crane Utility Truck (A59230)
2005 Mitsubishi...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
