zing
Platinum Member
I was wondering if the drain was to be used for air from the start. I think with a roof vent you should get a bit of a thermosiphon draft...I know the root cellar plans I have seen all seem to be set up that way, with an upper vent and a vent to floor level.
Just be sure to "vermin proof" the daylight ends. I have a bad enough time with chipmunks and squirrels in my fruit trees and veggies as it is (and if the gardens weren't fenced, I'm sure the rabbits and woodchucks would also help themselves). We stored potatoes in the basement one year...mice found them.
I like the dumbwaiter idea, but here's another possibility: just a series of well spaced shelves.
Open the doghouse, set crate on top shelf.
Climb in, down a bit, then move crate to next shelf.
Climb down some more, next shelf.
I'm envisioning them spaced stairwise on either side of the ladder/stairs, but you get the idea...separate moving the crate from moving you. Just a thought, I don't know how it would work in practice.
How about a trampoline on the bottom? Stand at top step with armload of food, jump from the top step and when you bounce up put stuff on a shelf. back down to trampoline and then bounce right back out the door.
