Propane "Odorant" - Can The Odorant Concentrate?
   / Propane "Odorant" - Can The Odorant Concentrate? #11
Cadplans, I used to sell propane. What you described is exactly what happens, and the older the tank, the more mercaptan oil resting on the bottom of the tank.
Well,, the 1,000 gallon tank was filled in June when we caught a ridiculously low (for our area) price per gallon,,
A couple times, I almost turned on the heat to see if the smell was gone,, but, it never got cool enough even for a test,,
TODAY, the wife acted chilly this morning,, so I jumped up,,, TEST DAY!!
Sure enough,, no smell whatsoever,,, WOOT!! Success!! I gotta be more diligent in filling that tank,,, :eek:
:thumbsup:
   / Propane "Odorant" - Can The Odorant Concentrate? #13
For all intents and purposes, that tank is EMPTY. LP tanks are only filled to 80% at the FULL mark (allows for expansion) so you only get 800 gallons to start with and below 20% (which is EMPTY on the gauge), you begin to lose vapor pressure and get the stronger mercaptan smell; same thing with grill tanks, when they near empty, they stink. So in a 1000 gallon tank you really only get 600 useful gallons of LP volume. If you are at 10%, you are cutting it real close to empty; around here, if YOU run a tank out, the LP company mandates a leak test (at your cost) before they will refill.
+10 on that. I hunt with the owner of the local gas company and everything you state is 100% correct. Least the never charge me a recert if I drain one completely. I have 2 500 gallon bottles in tandem.
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A57024)
2010 Ford F550...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A57192)
2001 INTERNATIONAL...
