Propane "Odorant" - Can The Odorant Concentrate?
   / Propane "Odorant" - Can The Odorant Concentrate? #11
Cadplans, I used to sell propane. What you described is exactly what happens, and the older the tank, the more mercaptan oil resting on the bottom of the tank.
Well,, the 1,000 gallon tank was filled in June when we caught a ridiculously low (for our area) price per gallon,,
A couple times, I almost turned on the heat to see if the smell was gone,, but, it never got cool enough even for a test,,
TODAY, the wife acted chilly this morning,, so I jumped up,,, TEST DAY!!
Sure enough,, no smell whatsoever,,, WOOT!! Success!! I gotta be more diligent in filling that tank,,, :eek:
:thumbsup:
   / Propane "Odorant" - Can The Odorant Concentrate? #13
For all intents and purposes, that tank is EMPTY. LP tanks are only filled to 80% at the FULL mark (allows for expansion) so you only get 800 gallons to start with and below 20% (which is EMPTY on the gauge), you begin to lose vapor pressure and get the stronger mercaptan smell; same thing with grill tanks, when they near empty, they stink. So in a 1000 gallon tank you really only get 600 useful gallons of LP volume. If you are at 10%, you are cutting it real close to empty; around here, if YOU run a tank out, the LP company mandates a leak test (at your cost) before they will refill.
+10 on that. I hunt with the owner of the local gas company and everything you state is 100% correct. Least the never charge me a recert if I drain one completely. I have 2 500 gallon bottles in tandem.
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
2003 JOHN DEERE 110 BACKHOE (A52707)
2003 JOHN DEERE...
Year: 2008 Make: Ford Model: Econoline Wagon Vehicle Type: Van Mileage: 88,245 Plate: Body Type: 4 (A55852)
Year: 2008 Make...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
