Propane Usage Meter
   / Propane Usage Meter
Well that shows you what a dip Sh** I am.
I didn't know what to expect for Winter usage. So you think a 100 gals a month is OK then? I guess I was thinking that was a lot but now I know different.
Yes, he does have a metered printed out statement he gives me after filling. It has the number of gallons and price and other stuff on it. So I guess I'll quit worrying about it.
Thanks guys...
Rob-
   / Propane Usage Meter #12
Rob, I know how you feel. I have a 975 sq ft house. I am on a keep fill with the local Co-op. I had my tank topped off two months back. They just added 216 gallons today. I run a pellet stove 24/7. I just had $8000 worth of energy efficient windows installed early fall. They did have a printed reciept on the truck but I still have a problem believing I used that much LP. I can't imagine that I am getting robbed by these people but I am a checks and balance type of guy and I want to know where all the juice is going. I went online to find a meter and low and behold the first search is Tractorbynet.
   / Propane Usage Meter #13
I am on a keep fill with the local Co-op...
Even with a Co-op I trusted I would not be on a keep fill basis.
In my case, a 250 gallon tank would have been about a $50/year rental, a 500 gallon is only $85.
For the extra $35 per year I get to have it filled in September, when propane is at a summer season prices, and then I can order and add propane 50 or 100 gallons at a time at winter rates until I make it back to summer rates.
A keep fill contract guarantees you are buying most of your propane at the higher winter rates...
I probably save $300-400 per year this way.
   / Propane Usage Meter #14
we are heating a large home, approx 6000 sq ft and thankfully we have a geothermal unit that helps out a lot. we have a 250 gallon tank that is buried in the yard. We thankfully only fill it once a year in September. (last fill price was $1.699) We only use gas to cook with and for a pool heater. I would not have purchsed this house if it wasn't for the geo unit...we couldn't afford to heat it.
   / Propane Usage Meter #15
I have a buried 500 gallon propane tank. Each season I pay for the smart option. It requires delivery of at least 400 gallons a year, be on the budget plan and allow unlimited access to the tank. This year the locked in NTE gas cost is at $2.45/gallon from Oct to April). If gas is less I pay the lesser cost. I pay $100/ month year round. Also get the start/stop meter card showing the number of gallons/cost in my door with each delivery. They deliver based on temps/my home history.
Propane is used for heat and hot water. Because I use little propane in the summer but still pay the $100, by the time November comes and we start using heat, I have built up a pretty good credit with them from the summer. My reconciliation month is each September.
Meant to add: Not sure if I am getting robbed or not but the last 6 years I appear to average about the same per month heating costs ($220- 240/month). I'd guess much of the constantcy is due to the fact that during anticipated long cold snaps I tend to lower the thermostat to save money.
   / Propane Usage Meter #17
i track my usage via the gauge on the tank... i try to go out every week on the same day and write the number down on the calendar.
i avg about 3% a week for my house. furnace, cook stove and dryer. I also put the numbers into a spread sheet and graph it then trendline out the current best fight line to find what date ill hit 5%... (ie will i make it till spring without having to rebuy durring high winter rate, and if not how do i need to adjust my budget or thermostat to make it work)
   / Propane Usage Meter #18
In case some of you don't know there are massive regional differences in propane costs. Right now the average cost in Nebraska is $1.73 a gallon; in New Jersey it is $3.96 a gallon:
Residential Propane Weekly Heating Oil and Propane Prices (October - March)
After posting yesteday I went shopping and returned as the propane truck was leaving the driveway. Propane ticket shows I was charged at the max locked in price of $2.45/gallon. Hard to believe there is such a disparity of prices. Here in my areas of VA, the price of regular gasoline keeps tottering just below the $3/gallon mark. Throughout the week it drops/rises between $2.94 and $2.99 per gallon. So far no station wants to be that first one to hit $3.
   / Propane Usage Meter #19
Is there a meter I can get to determine propane usage?
I'm a routed customer and the tank gets filled periodically. I'd like a way to check the amount of gallons I'm charged for is somewhat close to what I'm using ... if you know what I mean.
Thanks,
Rob-
We are developing a new technology for the measurement of residential propane usage. Check it out on our Facebook Page.
https://www.facebook.com/pages/ProReg/314099732118701?pnref=lhc
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
Utility Trailer (A52377)
Utility Trailer...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
