Property lines
   / Property lines #31
shaley said:
Consumer grade GPS reads to a 3 place decimal. 6070 ft in a mile so the resolution is +-6 ft. That is resolution only and accuracy can't be better than than stated resolution and most are about +- 15 feet with the WAAS system functioning.
The real time in marking property lines is clearing the brush for line of sight. Clear your line and ask a surveyor what he would charge to shoot the line. I bet he could do it in an afternoon.
Good advice Shaley, but we use a much shorter mile in these parts :D
Our GPS gives sub-centimeter accuracy with post processing. Also, pine trees can really mess up your reading. Something about the needles being the same length as the radio wave. GPS is nothing more than a calculating a distance-distance-distance-etc. intersection. The more sat's you read, the better your results, Ours read up to 12 at one time. Only problem is sometimes there might only be 3-5 that are readable.
You don't have to clear the property line for the surveyor. Just get a line cleared close, less that 30 feet would be good, dosn't even have to be straight, dosn't have to be very wide, line of sight is all thats needed. Any surveyor should be able to run a "random line" traverse , zig-zagging around trees when necessary and then calc a perpendicular offset from the traverse line to the property line. The more traverse points, the more points they have to mark your line from. If they make one long shot from corner to corner then suggest that they set some POT's ( point-on-tangent ) along their traverse line for you so there are intermediate points to mark your line from. Sometimes we will prepare a sketch for the client showing the offset from our traverse line to the property line so they can save a few bucks by marking the offset themselves.
The main problem with running just one line is that the Surveyor can not tell you that is your property line unless he has already done your whole parcel. All they can tell you is that they are marking a straight line between two points for you. Whole lot of liability issues there.
Bruce
RPLS 5781
   / Property lines #32
I marked my property lines with a compass (corrected), existing corner stakes, and long aluminum poles with survey tape wrapped for visibility and levels strapped on for for plumb). I then set painted metal stakes every so often and put up posted signs. The "long" lot lines were 1400' long, heavily obscured with scrub/trees, and steep. My neighbor saw the results and thought I had posted most of his property so he brought in a surveyor. My largest error was 1" so I was impressed (so was the surveyor). The neighbor got disoriented every time he went in the woods so he thought he owned his property and mine! Even though I did well, I personally would not use any non-professionanal method on a large lot to determine lot lines for anything important such as buildings or cutting down any trees. If you make a mistake, it could be costly. I would not even slash the property line without approval from the neighbor in case you are off a little. For putting up posted signs, I did not have a problem doing my own work. In hind site - I should have mentioned it first to the neighbor as recommended here but I thought it was a fairly straightforward project and did not foresee the problem.
Ken
   / Property lines #33
Moss, were you thinking of Wild, steel tapes, plum bob's, thermometers, small line levels and tension gauges??:D :D :D
   / Property lines #34
Bruce, I agree with you and Shaley. I'd say you need to "bite the bullet" and hire a surveyor. That's what I did on one of my properties. They did a great job on marking the line about every 200 feet. I put t-posts down by each pin to mark the line and now it is a snap to clear brush and sight right down the line even though the corners are not visible to each other. There are many more benefits to a good survey than just knowing where your line is. The credibility of your line for legal purposes is established by an unbiased source. I am a great fan of surveyors.
   / Property lines #35
No. I confess... I was just being a smarty boots. :eek::eek::eek: :)
   / Property lines #36
What ever hapened to a "Texas Mile"
The county I live in was founded in 1635. Make for some interesting reading for metes and bounds deeds/plats. I'm amazed how many 100 year traverses I've come behind and found they closed within 1/20,000 which is still our standard today.
   / Property lines #37
Moss; for the touchy stuff I forgot to add the six place log tables!:D :D :D
   / Property lines
OK, While we are on this subject of property lines - I have one neighbor that is a real pain - And I'm going to be putting up fence soon - What I'm planning to do is put my fence (not on the boundary between us) but on 8 feet onto my land). My logic being I can then mow outside of my fence and keep the brush off, so it will last a lot longer. I can also drive my horse and cart down that lane. My concern is, he'll think the fence represents the property line. I know many will say, meet him and discuss it - He's a Mega Land owner - And he lives out of the state. Any thoughts/ideas/concerns
   / Property lines #39
Yes. Every 50-100 yards sink a 4X4 post with a birdhouse on it right on the property line. Then put your fence 8' into your land. Make it a nice, mowed lane and there will be no question as to who owns it. :)
   / Property lines #40
That seems like a good way to set yourself up for adverse possession. To prevent that, you will have to give him written permission to use that eight feet -- or somehow keep him from using it. Either way, I would expect problems if he is the pain you say he is.
You might find it worth your while to buy an hour of a real estate attorney's time.
30006 (A53424)
30006 (A53424)
2014 Ford F-150 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A55788)
2016 Freightliner...
202476 (A54757)
202476 (A54757)
2000 Ditch Witch 3700DD Ride-On Trencher (A55787)
2000 Ditch Witch...
