pros and cons of net wrap ?
   / pros and cons of net wrap ? #21
why is that ???
It is on the small side for a baler that size, that's all.
For example we pull 4x5 balers with 80 - 100 PTO HP tractors.
It will probably do fine, I just wouldn't want to.
   / pros and cons of net wrap ? #22
I agree. It's frustrating trying to get a bunch of work done with a tractor that's struggling to get along. Not impossible, but not ideal , either.
hummm? vermeer said the rebel was rated for a 40pto ...???
my tractor according to tractordata.com says its a 48pto..
i sure don't want to buy another tractor... i just paid this one off.
   / pros and cons of net wrap ? #24
I'm running a 4x5 (504G) with a 60 pto with no problem. Maybe if the 4x5 is a lil to much, you could stop at 4'. (4x4)
   / pros and cons of net wrap ? #25
The only disadvantage for me with the wrap is that by the time I dump it in its spot and can walk around it four or five times to unwind the wrap, I'm fighting cows and trying to keep from getting trampled. If its twine I can usually cut across the bottom with my pocket knife quickly and go around to the other side and pull em out before to many cows get there. Of course y'all may know a better way.
I tip the bale on end and use a knive or razor knife and slice down the side. Usually no problem just peeling it off.
   / pros and cons of net wrap ? #26
why is that ???
He's thinkin' that 48hp is on the shy side of being able to handle that baler. The 4' JD balers (with net wrap) that I've been looking at have a minimum of 55hp @ pto. The Vermeer might be lower.
AKfish
   / pros and cons of net wrap ? #27
Nobody suggested you need to replace the tractor.
oh i know that .. it just feels so good to get it paid off.
   / pros and cons of net wrap ? #29
my biggest problem with the bale wrap is when it's froze on the bottom it takes a while to cut and get it all off, other than that works good.
   / pros and cons of net wrap ? #30
If you carry bales with a loader, lift frozen bales as high as you can, then drop them before placing them & cutting the net. Helps out with the frozen stuff.
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
54in Loader Fork Attachment (A59228)
54in Loader Fork...
Kubota LX2620 (A53317)
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2020 FREIGHTLINER...
