Pros/cons of tier 4?
   / Pros/cons of tier 4? #51
I remember back in the early 70's when the catalytic converters first starting going on the gas engines. There were lots of problems for several years, then they got much better. Hopefully the emissions controls we are seeing now on the diesels will improve too.
Yes, but those were/are passive catalysts. The diesel are active catalysts - they require constant dosing with Diesel Exhaust Fluid (DEF = urea) to operate. That requires feedback sensor & control, plumbing, computer, etc.
   / Pros/cons of tier 4? #52
There are no few sensors or computers on an egr engine. It just looks simpler thats all. And the looks here are very deceiving.
   / Pros/cons of tier 4? #53
I guess a better explaination would have been because we have no choice. The requirement are we meet a certain level of emmision, with that being said, the egr found its place. It is the most effecient way of acheving the end result. The end result being cost. The DEF system is much more expensive. I totally understand the lost of effeciency, but we have to meet emmisions. DEF system still use EGR so now I have to deal with EGR, plus DEF fluid wheres the gain? 1 gallon of DEF fluid for every 20 gallons of diesel? A hole another tank and injection system to worry about, plus a coulpe more sensors in the exhaust. Trust me I hate all of them.
   / Pros/cons of tier 4? #54
09 f250 w 6.4. Installed a spartan tuner and dp back exhaust and get about 15 percent better milage at stock power level.
There's good reason Ford only made that engine 3 years. I've had the pleasure of working on this engine, I think engineers took a little of every technology and stuck it on this engine. Sorry to hear about your problems.
   / Pros/cons of tier 4? #55
I hate it too. They took the most thermally efficient internal combustion engine there is & wrecked it in the name of "zero emissions". Yet diesels produced much less CO2 (greenhouse gas) than the spark-ignited engines, and used significantly less fuel (before fuel injection retarding schemes).
So once again, EPA is overzealous & not weighing total tradeoffs between all costs & all benefits of reducing ALL harmful emissions against other alternative engines & fuel consumption.
:hissyfit:
We have the best government that money can buy off (or be sued by puritanical environmental extremists).
   / Pros/cons of tier 4? #56
You are partially correct but the larger high hp diesels on many machines only use DEF except deere and Cat who will be using both systems. We are stuck with it for the time being but what goes around comes around and the EPA has gone way over the top and when all this equipment starts costing the economy billions in repairs I predict the present crap we have will disappear.
   / Pros/cons of tier 4? #57
:hissyfit:
Let the aftermarket take over here. The vehicles reset up by such companies as "bully dog" have made tremendous power in Dodge & Chevy trucks. Some of the same applications can be applied to diesel tractors. Where ever there is a market to make money products will become available. It took a long time since the 70's and 80's till vehicles became reliable and were not gas guzzlers. The DEF system with fluid having to be filled $$$$$$$ sucks. Also sounds like DEF system is short lived. Hopefully tractors and diesel equipment will not take as long to evolve as gas engines did.
   / Pros/cons of tier 4? #58
Now I really really wish I coulda gotten a 1026r before they came out with the smog controlled 1025 ******** !!!
Some have said the only difference in the engine is the model year and horsepower badge. Last year 26 horsepower, this year 24 horsepower.
   / Pros/cons of tier 4? #59
If the DPF and other tweaks raise questions, one may consider looking at Mahindra. Some have said Mahindra redesigned there engines and do not use emission "Add On's" to get in compliance.
   / Pros/cons of tier 4? #60
I like the sound of that if it is true.
I am convinced that we are being sold a bill of goods with this emission crap.
New/Unused CFG Industrial MX50R Mini Excavator (A57453)
New/Unused CFG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JCB 532 7,000LB Rough Terrain Telehandler (A56857)
JCB 532 7,000LB...
Takeuchi TL10 (A57148)
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
