PT designed muffler for the 425 Kohler engine
   / PT designed muffler for the 425 Kohler engine #1
bubenberg
Platinum Member
Bucks County, PA
PT425, Kubota L2050, 3 hydrostatic Exmark mowers. Z21D Kubota ZTR, 2 Kunz acrease wing mowers, 1 rough cut kunz mower, one vintage grasshopper ztr, one vintage gravely ztr, various large garden tracto
What a difference after we installed the pt engineered (by Ed, the owner and chief engineer). The engine runs even quieter than before and we operated the machine pushing around slush mixed with salt and cinder for a good hour. the black box protecting the engine was barely warm.
the principle of the pt muffler for the 425 is very simple, sturdy and ingenious. to reduce the heat, there are two pieces of pipe (about 2.5" long) welded to two comparable holes in a rectangular box. on one side the pipe goes halfway into a chamber and on the other side it just stops at the rectangular box.
with this design, and very effectively, cold air is sucked into that chamber and out comes a less hot exhaust gas, have not measured the temperature again. hopefully i will not have any battery tops melting, like the one last summer, with this new muffler.
one word of caution make sure you ask for the support bracket. i did not get mine when i was down there (because i did not know of it's existence), the pt muffler can't be held up by the four lousy bolts, Kohler provides, for too long.
   / PT designed muffler for the 425 Kohler engine #2
Hans,
What was the cost of the new muffler? Any chance they are working on one for the PT422?
Duane
compared with the on line Kohler mufflers (around $179.00) pt's is a bargain $98.00.
will find out and keep you posted.
yes, they have the pt made muffler for the 422 in stock, at the grand price of $98.01 plus shipping, creating and handling.
   / PT designed muffler for the 425 Kohler engine #5
...YES!!...
That's /w3tcompact/icons/cool.gif but I'm still gettin' an Optima. /w3tcompact/icons/smile.gif
   / PT designed muffler for the 425 Kohler engine #6
what's an Otima
   / PT designed muffler for the 425 Kohler engine #7
Tim,
It's a sealed HD battery...trying to prevent PT corrosion from leaking."boiling",vibration,etc. similar to what happened to my Cub...
When the PT "slope" capability gets to 180 deg(upside down)/w3tcompact/icons/grin.gif this is the battery the factory will install./w3tcompact/icons/laugh.gif
[/url]http://www.optimabatteries.com/usingOptima/applicationsRed.asp
   / PT designed muffler for the 425 Kohler engine #8
Not sure what I did wrong trying to make that a link.
   / PT designed muffler for the 425 Kohler engine #9
   / PT designed muffler for the 425 Kohler engine #10
Alternatively
{url=http://www.optimabatteries.com/usingOptima/applicationsRed.asp}Any text here you want (Helps with long urls) {/url}
<A target="_blank" HREF=http://www.optimabatteries.com/usingOptima/applicationsRed.asp>Any text here you want (Helps with long urls) </A>
2019 Peterbilt 520 Front Load Garbage Truck (A45336)
2019 Peterbilt 520...
Pull-Behind 150in 7-Reel Mower (A44571)
Pull-Behind 150in...
AGT QK20R (A46443)
AGT QK20R (A46443)
2025 Safety Basket Forklift Attachment (A44571)
2025 Safety Basket...
2025 LandHonor LHR-LB8850 UNUSED Leaf Blower (A47484)
2025 LandHonor...
2015 Cummins ISL Turbo Diesel Engine with Transmission (A44571)
2015 Cummins ISL...
