PT1850 Tire Pressure - 10 Ply Tires
   / PT1850 Tire Pressure - 10 Ply Tires #21
Wow, your property looks great. Super Jealous. I am thinking of welding a handle on the ROPS right where your hand is. A nice " O sht" handle.
Lol, dont be. That's the previous owner at his beautiful mountain top property before I purchased it.
Here's my "work in progress"
   / PT1850 Tire Pressure - 10 Ply Tires #22
So I was at a bit over 40. I stopped. I looked down the hill, If I had stepped off the tractor on that side I would have tumbled. It was a big drop from the level seat to the ground at that angle. Going up hill was the only choice and it was a scramble, hands and knees for traction.
I don't get how guys do this without having an out at the bottom (guys who mow dams on the water side). I have never been that steep without a clear cut way to get out not if, but when, you slide down the hill. It is truly scary, even with a leveling seat, to be that steep. My puckerometer really has issues beyond 30 even though I know it is completely safe, get beyond 40 and I am clutching the ROPs and freaking the heck out
4570. I am sure the PT 1850 can go beyond 45 without flipping. The problem is there is not traction beyond 45. There is barely any at 40. I ponder putting on those steel wheels with big spikes, the ones on that custom walk behind/ ride behind sold in germany. That would be some serious stiction.
I agree with the out at the bottom part. I’ll try nearly anything with a flat spot at the bottom. Add in a water hazard or retaining wall and the limit of what I’ll try is way less. I’d still like to see a machine operate on 45 degrees with rubber tires. 30 isn’t that bad, but I think 45 degrees looks great without mowing it!
   / PT1850 Tire Pressure - 10 Ply Tires #23
I've got a couple spots that will be up there. If I build up enough courage, I'll make sure to take video of the operation. I have to mow and clear a couple acres before I get there, so I should have plenty of practice!
   / PT1850 Tire Pressure - 10 Ply Tires #25
Avi. Your shop. Is that. Final choice in siding or what are your plans?
That's a point of contention around here.
It will likely be red. Some combination of board and batten and shakes. Maybe vinyl.
Though the green is growing on me.
   / PT1850 Tire Pressure - 10 Ply Tires #27
I've always wanted a red barn with white trim and a green roof.
   / PT1850 Tire Pressure - 10 Ply Tires #29
That's an interesting attachment system they have there. I'm very glad they evolved past that!
   / PT1850 Tire Pressure - 10 Ply Tires #30
Yeah, it was kind of 3point'ish. The quick attach is so much better.
2023 John Deere HD50F Draper Head (A53342)
2023 John Deere...
City of Buckhannon - 1990 International 2574 Truck (A52384)
City of Buckhannon...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
