Chipper PTO chipper/shredder
   / PTO chipper/shredder #21
They look so cute together.
   / PTO chipper/shredder #22
I just bought a wally BXM 32 and love the thing. I have used the chipper more, then run the chips through the shredder if I want them smaller. The BXM32 takes all I can throw at it. Keeps 2 people feeding it and never misses a beat. I researched them heavily and looked for used for over a year. There was not one single wally chipper shredder for sale in over a year within 500 miles that I found. I have a link with a video:https://www.youtube.com/watch?v=7X24sPvBN3A&feature=youtu.be
   / PTO chipper/shredder #23
Oosik,
Yours is the first post I've seen from my neck of the woods. I have 20 acres of pine forest to clean up. What is your opinion of the chipper vs chipper/shredder? I'm worried about all these fir and spruce crowns feeding well in the BX-42.
Also, if I buy the BX-42 I'll be feeding a lot of 4" material since that is still a bit small to burn. How does the BX-42 handle a solid 4" log? I've got 35hp at the PTO.
Thx,
Brett
My BX42 handles 4" logs with no problem and I have quite a bit less PTO HP than you do. If I was to do it over again I would buy the BXM42 for the shredder and I only have 3 acres of pine forest to your 20. Straight branches are always the easiest to feed into the chipper and the leftovers are best fed into a shredder hopper. They'll go through the chipper too but not as fast as the shredder. My father has a Bearcat chipper/shredder and I've seen how fast that shredder eats whatever is put into it.
   / PTO chipper/shredder #24
Well I have had the Wallenstein BX42 chipper about 3 years now. :thumbsup: I would stick with Wall. company if I wanted the brush chopper unit. Just have nothing bad to say about the unit. I keep a factory looking edge on the blades by never letting them round over like mower blades. :) That means a light sharpening every 2-5 hours of use. It's not that difficult and so much easier than letting them get really bad. :2cents:
Do you just run a file over the edge? I haven't sharpened mine yet and I've got at least 10 hours on it. I haven't noticed any negative effects on its chipping ability yet. Maybe because most of what I put through it is pine.
   / PTO chipper/shredder #25
Pinetree,
Long before you will see any effect on chipping ability you will find it stops self-feeding. It happens gradually so you may not notice it until you suddenly realize you are having to work more than you should to feed it. They will still feel sharp to the finger when they are too dull to self-feed. Ten hours, especially if you are doing soft wood with no dirt or stones on it is well within the normal life of a sharpening.
I doubt you can touch them with a file. You can use a bench grinder if you are very careful to not over-heat them - keep water handy and dip them often. But it's hard to keep them even. I get much better results with a sharpening system that runs wet and slow. I use a Tormek machine that also has provision for keeping the blades at a fixed angle that works very well.
Terry
   / PTO chipper/shredder #26
   / PTO chipper/shredder #27
I've got the Tormek T3 and it's a great sharpener. I don't use it as much as I did when I was doing a lot of woodworking, though. It was great for sharpening chisels, turning tools, hand plane blades, etc.
   / PTO chipper/shredder #28
Mine is an older model, at least 5 years and probably closer to 10 years old. It has a 10" wheel which makes it like the T7. It's worthwhile just for sharpening kitchen knives - my wife is so pleased when I do that!
I use the planer blade attachment for chipper knives, which makes it easy to get a uniform bevel on the whole set. Mine came from Garrett Wade in New York.
Terry
   / PTO chipper/shredder #29
Terry
I just went and checked mine, and I was wrong. It's not the T3. It's a "Supergrind" and has the 10" wheel. So, I suspect it's the same model as yours. It's green instead of blue and I've had it for 10 - 12 years.
Yikes, I didn't know they had gone up so much in price. But they are great.
   / PTO chipper/shredder #30
Thats for all the feedback. I am still leaning toward the Wally. I had my dealer quote it, $3690+tax+~$100 shipping. No way I am paying that. I contacted Woodward Crossings, $3199, no tax, shipping is $250 or I can pick it up (~4.5 hour drive), and a free set of extra chipper blades!
I think the Bear-cat would be my first choice, if the blower kit was included.
I hope I'm not too late to join the party! I have a Wally BXM32 that I ran for ~3 years behind a JD2305 (18PTO HP) with no problem. I love how stoutly the unit was shipped, it was easy to do the assembly off the pallet, and is a dream to work with. I too, bought from the good folks at Woodward Crossing. You can't go wrong with them. Isn't there a business near you with a loading dock or forklift that you could have your unit delivered to? It would sure beat a 4 hour drive ...
Frank
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
2014 Ford Expedition SUV (A55853)
2014 Ford...
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
