Pto damage
   / Pto damage #11
I learned some of this the hard way. Some of my u-joints are damaged, but so far are working fine, on my roto-tiller. The setup instructions are written by a nit-wit. There was absolutely no mention of checking the angles when the tiller was raised. If the damage had been worse I would have consulted a student lawyer for advice. This has been a good remedy for me a few times.
   / Pto damage #12
Sounds like PTO is being raised outside of tolerance of the u-joint.
   / Pto damage #13
I am not supposed to raise the cutter or tiller up all the way up when it is running and that is what is causing the damage and it is my fault for the damage. ....
If the shafts are to long , it will not matter if it's running or not it will still have the issue.
   / Pto damage #14
Can you post pics
   / Pto damage #15
My Woods tiller instructions say not to lift the tiller any higher than necessary to clear the ground when tiller is in operation. I always assumed it was a safety issue with the tines turning an all. I never even considered that it could damage the equipment. I'm glad this came up before I did something like it myself. Although I feel bad for the OP. That's go'tta suck. I would like to see the picks too if they are available.
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
UNUSED SDLANCH SDLD 25 HYD DUMP BUGGY (A57192)
UNUSED SDLANCH...
ATTENTION! PLEASE READ (A56469)
ATTENTION! PLEASE...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
1840 (A51248)
1840 (A51248)
