PTO Generator Choices
   / PTO Generator Choices #1
AndyMA
Elite Member
Windham County, Conn
Ford 2120 , Kubota MX5200 , Deere X748SE. 1956 Economy Tractor
Hi I've been looking at PTO generators for years
I was looking at 15 kW but think 10 kW would suffice as my house is highly energy efficient . Zero Net with Solar PV
1) Harbor Freight PTO Generator - Tractor-Driven PTO Generator, 16,000 W Max
2)IMD Amazon.com: PTO Generator Kit 10 kW (10,000 Watt) 3 Point Carrier and PTO Shaft Drive Line Included: Home Improvement
3) Voltmaster Voltmaster PTO15/12 - 12 kW Tractor-Driven PTO Generator 540 RPM
4)Winco Winco W15PTOS - 15 kW Tractor-Driven PTO Generator 540 RPM
Comments suggestions?
Andy
75HP New Holland TN75D 24HP John Deere x748SE
   / PTO Generator Choices #2
AndyMA
I do not own a PTO generator! ( I have a water cooled, OHV, 6500W Honda, with electric start )
For what it is worth, I would think the Harbor Freight one might be the way to go.
In the reviews to date, only one buyer out of 16 gave the HF PTO generator a bad review.
HF has 20% discount coupons all the time, so you could get one of their generators for $1300 - $260 = $1040 + tax.
Then too, if it does not operate the way you think it should, it would be very easy to return.
This, of course, is all predicated on there being a HF store within reasonable driving distance.
   / PTO Generator Choices #3
I am happy with my Northern Tool PTO generator. Have only used it a few times but it has done well.
   / PTO Generator Choices #5
I purchased a Baumalight TX-12 3 years ago. It was more money than those listed, but it runs very nicely. I run it with my B2920 Kubota or my 1947 Farmall H. It is a smooth running generator and easily runs my entire house.
BaumaLight - TX Model PTO Generators
AndyMA
Thanks I tried to buy one at a store, we now have 4 within 30 minutes and they don't stock them. Unfortunately the 20% coupons I get exclude generators. Have you seen one that allows generators? Thanks
   / PTO Generator Choices #7
The 12KW Winco I bought several years ago is very solid unit. I've only used it a couple of times to make sure it worked. But then I only paid $600 for it with a new PTO shaft off CL.
   / PTO Generator Choices #8
I can power my whole house and separate garage with a 10K PTO generator.Well pump,hot water heater ,freezer ,fridge,furnace ect. Make sure you get one with a meter on it;also the proper disconnect switch.
   / PTO Generator Choices #9
I briefly looked into it a while back. The only thing of significance I found on the HF unit was that it had brushes whereas others were brushless. I did not form any opinion on the value/benefit of brushless.
   / PTO Generator Choices #10
For me considering this is an emergency backup the Hazard Fraught would be off the list. When you need it you need it don't want want to worry about it failing at the most inopportune time. My dad bought and returned a small compressor 3 times before he said keep it and asked for a refund. First was DOA, second worked a few times Over the course of a month. Turned it in for a 3rd and he said it cycled a few times while running a nailer then died first day.
Brother in law had to return his HF electric hydraulic log splitter twice to get on that worked well. First on lasted 15 minutes. Second one about 3 months. His 3rd lasted him 2 years before he finally bought a gas dirty tools.
Maybee its just me but when my power fails its either -5°or 95°F. and its usually out for 48 hours at a time. Last outage was 5.5 days previous to that 60 hours.
I'd go for any of the reputable brands. I looked at them all a while ago but decided ill just put in a propane standby. Cheaper to run.
“The bitterness of poor quality remains long after the sweetness of low price is forgotten”
   / PTO Generator Choices #11
Well, I have the 15KW Winco, it surges to 18K, it's been a good unit and I'd buy it again.
I like the idea of buying bigger than I needed, as I have no idea what the future will bring, and I can put it on a bigger tractor and run my welder, with lights lighting the area and someone running a side grinder if needed... I can also run it with a smaller tractor when I need less power and save some fuel.
If you are buying one for emergency use, don't try to save money by buying a lower quality unit!
SR
   / PTO Generator Choices #12
I have my fathers 15kw Winco generator now and it's worked flawlessly for 30 years. I too would go with extra power rather than just enough.
   / PTO Generator Choices #13
For: AndyMA
I just checked three different HF coupons, and you are correct!
The HF coupons DO exclude generators.
After giving it some additional thought myself, and reading other comments here, I think I would NOT buy a HF PTO generator.
"xring100" suggests a "propane standby" (fixed?) generator, and that actually may be the best idea.
A portable 8,000 or 10,000KW propane powered unit might be a good idea also.
Propane is the best fuel to use with a generator, as it has a FOREVER shelf life!
   / PTO Generator Choices #14
The only problem with propane is that you need a lot of volume. I would have needed a massive propane tank the size of a mid size car to give the same runtime as a 55-gal drum of diesel.
   / PTO Generator Choices #15
Exactly, and I don't have to have a ANOTHER motor to service like I would with a stationary genset... I always have my tractor ready to go, because it's useful all year long...
Do you remember what propane was doing last year??? (price and availability)
Diesel stores just fine, and I "wouldn't" bet that you can run a propane genset cheaper than you can run a small diesel tractor...
SR
   / PTO Generator Choices #16
I was asking the same question a little while ago. I ended up finally finding a Winco on Craigslist. 20kw 30kw surge & about 20 years old. $1k with the ratty old trailer. I'm hoping it turns out to be a better investment than a $1,500 Harbor Freight.
Still trying to get a disconnect wired up on the house for it.
   / PTO Generator Choices #18
While looking further into it I found that Winco once again is producing a "small" PTO generator - a 10 KW WINCO W10PTOS.
When I bought my 12 KW they had discontinued it and the 15KW was their smallest until now.
   / PTO Generator Choices #19
1 gallon of lpg is ~90,000 btu 1 gallon of # 2 diesel is 134,000 btu.
so 81 gallons of propane has roughly the same energy equivalent of a 55 gallon drum of diesel.
I own my Propane tank at its currently is $1.80 per gallon. So as long as diesel is atleast $2.71 a gallon its cheaper to opperate on propane. Last year during my last 5 day outage gas and diesel were closer to $4 and propane was 1.90
Also during that outage is used my tractor a lot to clean up the mess from the storm.
Operating cost and depreciation
Oil and filters alone cost me over $1.40 an hour on the tractor mostly thanks to 17 gallons of hydraulic oil. My generator holds 1.5 quarts good for 100 hours and a $8 filter. Im sure the standby generators dont cost much more for maintaining.
You can probably repace the whole engine on a 10-12kw standby generator for about the cost of an injection pump replacement or rebuild on a diesel.
Natural gas would be my first choice but i dont have that option.
ANTHONY CARTS 94LFW-24 OXY/ACCELYNE TANK CART (A60432)
ANTHONY CARTS...
Towable Dewatering Pump (A59228)
Towable Dewatering...
John Deere 4510 (A53317)
John Deere 4510...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
