PTO Generators: Winco
   / PTO Generators: Winco #41
20050924
I bought several pumps on a silly whim several years ago from Northern and your Pump 2 was one of them. The aggravation is not worth the cheap price. Skip it!
Cannot comment on the others but I wound up with a real one (ie, couple hundred$, service station type) for the 55 gal drum I am going to equip.
Northern has some in betweens, check 'em out.
Watch shelf life on diesel, specially in that NC heat, the stuff does go bad, even with preservatives. I would consider propane if you go standalone.
One thing also to consider--do you want to be hooking up a PTO generator in a storm?
Just food for thought, not meaning to be a party pooper,
Jim
   / PTO Generators: Winco #42
240vac at 50a is right at 12kw .. ANd yes.. you would need either a load trnasfer switch, or need to isolate your main breaker so you don't backfeed the grid..
Your hookup cableing needs to be of sufficient size for it's length of run so that you don't have a power drop.
Soundguy
   / PTO Generators: Winco #43
</font><font color="blue" class="small">( This one? Pump 1Or this one?Pump 2Or this one?
Pump 3
)</font>
Pump 2 is silly for anything but a 1-2 gallon lawnmower.. I had one and it worked your arm off to fill a 5g bucket..
I have the 19$ #1 pump.. works good.. I would have got the 39$ one if i would have seen it... etc.
Soundguy
   / PTO Generators: Winco #44
</font><font color="blue" class="small">( 240vac at 50a is right at 12kw .. ANd yes.. you would need either a load trnasfer switch, or need to isolate your main breaker so you don't backfeed the grid. )</font>
You're right. I should have been more clear in my response that he didn't need to do anything special to use a 240V generator. I was focusing on the fact that he shouldn't have to do any other rewiring of his house or get a step-down transformer or the like. I was assuming he knew that you can't just plug it in and go (never assume...). It does need to be properly isolated from the utility line. Of course this is true regardless of whether he has a 120 or 240 v generator. What I should have said was that there is nothing ADDITIONAL to do for a 240 as compared to a 120 v hookup.
I've got the mechanical interlock on my main circuit breaker, so I can't hook my generator up to the house without first disconnecting from the grid. Works great... I can use my regular panel to deactivate whatever circuits I don't want powered while running on the generator.
The only thing I want to add is some sort of indicator to tell me when the grid is back on. As it is, the only way I can tell is to disconnect the generator and reconnect to the grid. May something with an indicator light and a momentary contact "push to test" switch that would light up when pressed if the grid was back on. Have you ever seen anything like this?
John Mc
   / PTO Generators: Winco #45
How about a neon bulb on a push-to-test switch?
Soundguy
   / PTO Generators: Winco #46
Why does it have to be on a switch? Just wire the bulb off the in side of the main breaker, the bulb could be mounted right in the cover of the panel. I have seen this in alot of commercial applications.
   / PTO Generators: Winco #48
</font><font color="blue" class="small">( Why does it have to be on a switch )</font>
Doesn't have to be... just depends on if you want the neon bulb to be energized 100% of the time when the utility is on.
Soundguy
   / PTO Generators: Winco #50
Soundguy,
The electrician and I have dicussed things but I have been trying to figure out how many watts/generator we are going to use. I just want a simple switch to disconnect me from the grid. I dont' want fancy circuits that I see on some switches. I want to be able to manage things in the circuit breaker box in the house. I would like a light fixture of some kind on the grid side of the switch so I know when power is back on.
The funny thing is that now we are thinking of using a DR mower to run the generator. /forums/images/graemlins/grin.gif They have a 6000/5500 watt generator for their mowers. We need one of their mowers anyway, soooo.... The generator is 600-700 dollars which is the least expensive option we have seen even though 5500 watts seems to be the minimum we need to power the hot water heater....
Later,
Dan
2018 Kawasaki Brute Force 300 ATV (A55853)
2018 Kawasaki...
Elgin Pelican Street Sweeper (A55851)
Elgin Pelican...
UNUSED FUTURE CYHC 29" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE CYHC...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
UNUSED RAYTREE RMRB72 72" HYD POWER RAKE BUCKET (A57193)
UNUSED RAYTREE...
20205 Lucky Dak Electric Scooter (A55853)
20205 Lucky Dak...
