pto pain
   / pto pain #1
sjf
new york
tc29s
Would any of you out there be able to tell me why my pto will ingage but will not disingage. I called My dealer about it the other day. Well he must have showed up why i was at work.Went out to the barn this mourning and the lever was back to the disingaged position but when i ingaged it ,it got stuck again, I have a Tc29. Any help would be great
   / pto pain #2
My TC29 has @ 60 hours on it and the pto has been hard to disengage. First I allow the pto to come to a complete stop. Then go from forward to reverse while feathering the clutch (my tractor is a gear unit with the live pto). Usually if I jerk hard on the lever while doing this pto will disengage. And it still grinds part of the time. I will keep an eye on this thread to see if someone else has simular problems, or a better answer.
   / pto pain #3
You said your tractor is a TC29, not a TC29D, so this may not apply. ( I haven't seen a non-deluxe tractor lately)Check to see if the flat stock the lever is made of is twisted and is catching on the plastic shroud that the lever comes up through. If it is, use a cresent wrench to twist it back straight.
   / pto pain #4
Interesting, /w3tcompact/icons/hmm.gif I have a TC30 hydro with about 20 hours on it and the pto lever is very stiff and difficult to engage. It's pretty easy to disengage. The way mine is set up the rear pto lever and the mid pto lever are less than a fingers width apart. It's really difficult to wedge my fingers in there to move the rear pto lever. It never grinds but it sure takes some muscle to engage it.
Jerry
   / pto pain #5
Tech in Ny:
Thanks you just solved my PTO lever problem. A little tweak on it, and it slides nice and smooth now.
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
25077 (A51694)
25077 (A51694)
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A53342)
THIS WILL BE A...
